26-08-2012, 04:11 PM
Yeah mine does it on shitty road surfaces quite badly and I haven't even fitted my baker mounts yet but mine is derv so vibrates and rattles more than a perv
Spike2002's Silver Six
26-08-2012, 05:06 PM
(26-08-2012, 03:32 PM)Jonny b Wrote: f*ck me I have just been out for a drive since fitting the engine mounts and shit me does it vibrate, take it from the above yours does too? Yes mate rattles the sunroof. I expect it to be even worse now tho as my top mount has had the shims welded in
26-08-2012, 05:10 PM
Is yours stripped out!? I thought there was something wrong when I started it up lol
26-08-2012, 06:00 PM
Nah mate its not striped out. if you are striped then i presume it will make it worse.
Few pics after today.
26-08-2012, 07:36 PM
Looks sweet bud got a soft spot for silver cars especially 6's and the like
26-08-2012, 07:38 PM
Thanks mate still got few lil bits to do but its 99% there now will be finished tomorrow and ready for mot
27-08-2012, 05:12 PM
When is the mot booked in for bud?
Havent booked it yet mate probly get her in for nxt sat.
Just noticed my front fogs dont work and the clock/time display doesnt light up fuse mayb? Fuses are fine bulbs mayb.
27-08-2012, 06:17 PM
Front fogs shouldn't be a fail anyway as they're an auxiliary item - just depends if your tester is a dick or not. Clock not lighting up is bulbs in the back x 2 - eBay is your friend for these as Halfrauds are robbers.
27-08-2012, 06:23 PM
(27-08-2012, 06:17 PM)ash240970 Wrote: Front fogs shouldn't be a fail anyway as they're an auxiliary item - just depends if your tester is a dick or not. Clock not lighting up is bulbs in the back x 2 - eBay is your friend for these as Halfrauds are robbers. Not strictly true. There a safety feature and there fore if there installed, they should work! As you said, depends how nice the tester is.
Yes as niall said if they are fitted they must work good job my mot tester is friendly will get them fixed anyway im thinking green relay or bulbs.
I have spare bulbs for the clock in the shed so i will just swap them over and see what happens
28-08-2012, 01:04 AM
Dude, loving the purple masks, they look epic!
29-08-2012, 01:49 PM
(28-08-2012, 01:04 AM)samass Wrote: Dude, loving the purple masks, they look epic! Cheers dude. I will be fitting the rear boot badge. that gareth7 done for me tomorrow if the weather is good
30-08-2012, 08:40 PM
Fitted the gloss black and purple boot badge today and de wiperd her.
Sorted the time/temp clock out as the bulbs had gone just got to sort the front fogs out now as they dont work all plugged in checked fuse and green relay clicks so im thinking the bulbs have gone.
30-08-2012, 09:00 PM
If they're h3 bulbs I've got some you can have if your dad wants to pick em up from mine after he finishes work 2morrow - used for about 2mins to test the circuit then swapped em for 100watt yellow bulbs on my ph1
My rear bumper turned up yesterday may try and fit it over the weekend if I can get my dad to give me a hand.
im not sure what bulbs they are i have put thr crystal fogs on so i will just remove the bulbs from the frosted ones and swap them over
just hope its the bulbs as im not sure what else it could be :SOw and if you need a hand with the bumper im free sunday mate
30-08-2012, 10:13 PM
The only other thing it could be is a broken wire/earth which if both bulbs don't work the earth is more likely unless they've been blown by shorting out.
I am thinking they may have already been blown on the previous car or got f*cked while in the post as ive never seen them working. if not tho i will double check every think i have already checked and hunt the problem down
![]() Any idea were the front fogs are earthed to?
31-08-2012, 12:17 AM
Haven't got a clue where the earth points are for the fogs bud - sorry.
31-08-2012, 11:28 AM
Fingers crossed for the mot bud
01-09-2012, 05:12 PM
Bulbs in the fogs are h1. changed them and the fogs now work.
![]() mot booked for the 15th
14-09-2012, 10:40 PM
Good luck for the MOT tomorrow bud, hope she passes
15-09-2012, 05:57 PM
must say bud i like the purple touch its nice hahaha
Official Team Go-NAD fan club
| Spike2002's V6 ecosse project | spike2002 | 115 | 81,339 |
31-10-2013, 07:50 PM Last Post: Niall |
| Spike2002's sigma win | spike2002 | 66 | 51,259 |
09-05-2013, 09:06 AM Last Post: spike2002 |
