Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
Yea probably coming out the breather, think it's under load though as had pipe off when idling but nothing came out.
So it can be cleaned via the fuel system? Redex worthwhile, like if put it a highly concenrated amount?
Threads: 163
53
Car Model/Spec: 406 HDI
Given 18 thank(s) in 15 post(s)
Problem you'd have is the Redex would burn before it could seep down the bores. Maybe try pouring some kind of cleaning solvent directly into the cylinders through the spark plug holes and leaving it a few days? Should seep past and maybe break down the crusty oil? Starting it could be a bastard after though.
Threads: 541
124
GOtta say it does sound like piston ring symptoms (with excessive blow by causing crank case pressure and pushing the oil up the breather) as liam says though I cant see much less than a rebuild fixing it.
Threads: 581
195
Agreed with Liam and Chris unfortunately. Id put a drink on that being bad piston rings
Threads: 163
53
Might be worth just taking it out over the moors and beating the ever loving shit out of it for 100 miles...
Threads: 541
124
You can get a replacement engine off the bay for £100 and a ring set for £65 as i wouldn't just swap the engine as the replacement will probably be just as bad
Could probably get a cam, a ported head and a set of bodies while the engine is apart. A few of us are capable of building engines, some more so than others (don't let niall supercharge it)
Threads: 186
38
04-06-2014, 11:24 AM
(This post was last modified: 04-06-2014, 11:24 AM by lolsteve.)
Well apparently it's a bit better now its had the engine flush and oil change doesn't leave a cloud a smoke when starting up. Just need to see if the oil spitting out the back will clear up once the throttle sucks up the last of the oil on the drive to combe. Will advise some redex as well since i think she fills with a mix of tesco/asda fuel
Although the cam, ported head and bodies does sound tempting. maybe if I can convince ladysteves dad that it would fix the problem
Threads: 163
53
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
Tip for your tints if you are having issues.. Stick it against the outside of the window, and cut more or less to shape so you arent left with flailing huge amounts of surplus getting in the way
i love these things, always wanted one.
/Toseland
Threads: 186
38
We were cutting on the outside and trying to heat it with a hair dryer to shrink it and take shape but it wouldn't
Think an italian tune up might help, can imagine it's been driven on low rpm all its life with poor servicing
Threads: 80
10
Given 0 thank(s) in 0 post(s)
You guys are all mad, since when did a 54bhp car designed for carrying groceries become cool?
![[Image: sigjpg.jpg]](http://i44.photobucket.com/albums/f32/cassandra--gemini/sigjpg.jpg)
Serious.
Threads: 163
53
(10-06-2014, 09:38 PM)lewisdmz Wrote: You guys are all mad, since when did a 54bhp car designed for carrying groceries become cool?
Cool is not about capabilities or intentions. The original Mini was designed to carry 4 people and luggage as cheaply as possible. The Beetle was designed by Hitler. The 2CV was designed to carry a man in a top hat across a ploughed field. They're all cool as f*ck.
Threads: 541
124
^^^ What he said.
Wish I'd taken some photos of Allie's oil over my nice clean white car after it was given a bit of a rev on the camp site.
Threads: 186
38
16-06-2014, 07:13 PM
(This post was last modified: 16-06-2014, 07:16 PM by lolsteve.)
Threads: 476
81
Car Model/Spec: 306 Rallye
If only that was yours
Threads: 117
119
That actually sounds alright once it gets going...
Threads: 186
38
So many lack of updates
It's still spitting huge amounts of oil out the back, going to try and take the rocker cover off this weekend if the weathers nice to check the gauze filter make sure that's not blocked and perhaps spray the cover up in that colour seen above as it's quite nice
One thing that has happened is a exhaust trim I got from the scrappy for a couple of quid
Thinking of getting some atf and pouring it into the spark plug holes and letting it soak over the weekend see if that does owt
Threads: 61
11
Car Model/Spec: rallye,Astor 6
(02-06-2014, 06:05 AM)Piggy Wrote: Maybe some decent fuel additive to clean it all up? Forte do some decent stuff.
That or a second hand engine....they are cheap. Good excuse for a turboooooo! Maaaaaaaad!
YES
Then a rematch with rowell
Astor 6 Fast road/track project
Threads: 0
45
I got offered one of these with 28k on it a few weeks ago for £300! Didn't realise it was what ladysteve has!
Threads: 371
29
Car Model/Spec: ford fiesta
Given 82 thank(s) in 82 post(s)
Id have bit his arm off for 300 so much fun to drive. I sort of miss mine!
Threads: 9
0
Car Model/Spec: Citreon DS3 - 1.6 DStyle Turbo
Im sorry steve...whos car is this!? We are not doing anything to it this weekend. As if I would let ur clumsy ass near my car
French Wench
Threads: 186
38
Oh thought you didn't come on here no more  But yes that was my weekend plan to fiddle your car and make it jazzy
JJ was it a 3dr? I would have bought it for a daily/spares if it was. £300 is a bargain
Threads: 0
45
I think it was a 5dr, makes it more cool!
Threads: 87
48
Car Model/Spec: Rouge vallelunga 5 door Dturbo
Given 74 thank(s) in 70 post(s)
(07-01-2015, 08:04 AM)LadySteve Wrote: Im sorry steve...whos car is this!? We are not doing anything to it this weekend. As if I would let ur clumsy ass near my car oh no she ditant!  .....isn't it enough breaking your own car Steve? Leave the girl's/lady's alone why don't cha? lol
Threads: 186
38
Need a sticker saying "more doors for more whores although not too many or it won't go up a hill"
Naa I'm just jealous of her working car so I'm going to sabotage it
