Info on a cam.
Info on a cam.
#91
They are pretty bad boxes! Very weak!
[Image: Foxy2.jpg]
IIRC When i was on Sax-P you can get a conversion kit and run a 6' box on the TU engines
They're disposable gears, use once then throw away, make it lighter. You can run the BE box with a conversion plate but it gets pretty spendy as you need hubs, bearings, shafts, mounts, BE4R 'box and a load of other bits and pieces.
Might have a work with the bloke doing the gears for the buggy on a price for a new gearset tbh...
Foxy - watch how much you skim off, it needs to be matched to the engine flow/cam specs (mine had a fair bit of chamber work to help it with high compression) and you'll need to advance the cam timing if you take off as much as I did.
Foxy-jim Wrote:They are pretty bad boxes! Very weak!
Yep.....my old 1.4 has had 4 of them now lol! lmao Ok so they werent new ones but still, 65k and 75horses shouldn't be too much for any box!!!
Cheers Rip!
Ive gone through one box. On my 2nd now!
[Image: Foxy2.jpg]
