Torsion Bars.
#31
We had no luck with heat treated, pulled thread wheel studs when inserting in that hole in the middle, it pulled the threads in the end.
I think we ended up doing as maz-306-xs did and removing the swinging arm, resulted in as Ruan mentioned "on the floor"..... lol....
#32
(11-10-2012, 01:12 PM)Ruan Wrote: Off the car is a f*cking nightmare... I ended up pulling the bolt through the eccentric washer by attaching the other end to a post in the ground and sledge hammering it... It's just a total pig to do..
The only *easy* way to do it is to use a hydraulic bearing puller, that's the only way I removed mine, but you can only get them out of one side doing it like that, so you have only 3 options, OEM, 10mm lower or on the floor... Heat and hammers are the only way... Slide hammers you may as well not even bother with, every time I just break the slide hammer...
+1 on the slide hanmers ruan they are full of fail when it comes to 306 torsion bars. Socket and bolt is the only way iv ever managed to get them out
#33
(05-10-2012, 12:08 PM)kernow_joe Wrote: I have plenty of hammers so should be fine...
My mantra for most things Wink
  Torsion Bars/ARBs - Sizes and Sources anto 43 71,719 26-02-2019, 10:53 AM
Last Post: Mighty306
  Stubborn torsion bars Mighty306 12 7,690 09-06-2017, 08:07 PM
  Uprated torsion bars mossy1985 17 10,596 23-10-2014, 06:48 PM
Last Post: mossy1985
