Things left to do before fcs
#31
Fit oil cooler so can stay out longer on track / reduce risk of fking the engine - Highly doubt it'll get done now as really could do with a second pair of hands
Fit thermal intake gasket without a vacuum leak
Sort out front tyre as it's taken some abuse - - ordered a part worn continental to tide me over
Gearbox oil - Still time but not sure if I should
Fix abs sensor issue - removed cable tie, drilled out and replaced the broken bolt then sprayed wd40 on it before giving a wipe over and now seems fine...so will say its fixed
Fit MG TF steering wheel
Fit rear anti roll bar
New pads up front  - ordered but not yet arrived
[Image: mcetg0.png]
(26-05-2016, 05:48 AM)Piggy Wrote: How about just reduce your alcohol budget so you'll be sober enough to use the tracktime? Tongue
Alcohol Is already sorted buddy, got a 24 can case of Tennants and an emergency 12 can case of Stella.
I really didn't need the car costing me £500+ the week before the show.
Users browsing this thread: 7 Guest(s)
