can someone check a switch please
#31
passanger airbag wires go straght to the Air bag ECU as so the bypass switch the ecu does the switching off the switch is only an input to the ECU
your drawing is below if you havnt got side bags or seat belt warning lamp ignor that
you need to get your car on PP2000 it will tell you what is wrong with the airbag system
.pdf   airbag.pdf (Size: 177.14 KB / Downloads: 163)
.pdf   airbag2.pdf (Size: 102.53 KB / Downloads: 178)
many thanks for the pic awesome :-)
where is the best place to buy this from buddy?
the faults that show from a snap on solus machine are:
the numbers mean nothing lol
you think I have. broken wire?
p1862
of the passengers airbag deactivation not defined
and
p106f
passenger airbag deactivation undefined
you wont buy an original pp2000 but you can buy chinese clones for around £70-100
i still think you have a duff connection somewhere
I agree buddy in what you are saying
airbag light on
side airbag light no longer lights up
seatbelt light no longer lights up
I changed steering wheel
airbag pass switch
instrument bulbs to dash and centre console
I have pulled a cable I am sure of it but can't find it and believe me I have spent all last week looking :-(
much appreciated for your help
I am gonna check out eBay for the pp2000
you probably not got the seat belt buckled light!
id have another look at the steering wheel conections both of them
maybe duff squib?
snap on not coming up with that code though
good shout tho buddy
it's a small connector not a lot I can do with it to be honest
would not know where to start
dont belive what the snapon man sells you all the time hes after your money
no it's my friends unit mate
must get
me pp2000 kit
been looking on flea bay today
just had a car here with "passenger airbag deactivation" fault
its not the switch its the wiring between the ecu and the passanger airbag or the airbag itself on this car
didnt have enough time to get to the bottom of it though
good man thank you ill go take a looky see if I can find it
thank you!
changed clock spring squib :-(
no change
cully can you please give me a link for that fault buddy
I am back from hols now and way outa touch with this
need to sort the fault :-)
just had the car here again now
i have measured all the resistances and all is good only thing it can be on this car is a faulty airbag ECU now!
but the old wizard with his soldering iorn now has the airbag lights self checking and going off!
whistle
have you removed the plug on the airbag ECU?
if you have try plugging it in again as if the plug is out the SRS lights are on permanent
lol same fault on two forums and answering you in both
I wish I hadn't and could try this Sad
but I have tried this sorry buddy
and fitted a clean ecu too :-(
update lol
took both seats out tonight
marked cables cut and soldered
and
guess what
nothing :-(
battery was removed beforehand of course :-(
back from hols now so managed to so some more testing
we linked the snap on solus up to the 306 today and both faults went but we have now been left with this
P1041
Fault: Ecu configuation not correct
I am sure it's because the ecu, although it has the same code the rest of the details on the ecu are different :-(
