Threads: 591
54
Someone kindly stole 2 of the genuine rota centre caps while MrsPiggy was parked at a job.
They are tricky to find genuine and expensive....
So instead, custom set for price of one Rota cap...
Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Given 17 thank(s) in 17 post(s)
Nobs! Like the new custom ones though! May as well be silly if you can
Threads: 101
2
Car Model/Spec: 306HDi 90 LX
(12-05-2018, 06:54 AM)Piggy Wrote: Someone kindly stole 2 of the genuine rota centre caps while MrsPiggy was parked at a job.
alignment needs slightly adjusting. to make 2 bolts look like the eyes.
It goes, it stops (as reqd).
Hate Housework!
Threads: 101
2
some numbers from a short day trip.
figures as close as I could read.
Stock HDI 90.
speed 60
rpm 2k
water 75*c
oil 95*c
pressure 40-50psi
battery 14v.
Hate Housework!
Threads: 591
54
Thanks
We know stock HDi don't make heat...even tuned HDi stuff doesn't make heat.
Threads: 101
2
14-05-2018, 06:26 AM
(This post was last modified: 14-05-2018, 06:28 AM by Magenta Sunset.)
knowledge is power, wouldn't you say
the only time temps -esp oil, go up, is when queueing past Heathrow on the M25. then the oil indicates 110*c (gauge is slightly erratic), and water 90*c.
Hate Housework!
Threads: 591
54
Yes for sure... If I've learnt nothing else with my projects it's that information is worth 10x as much as parts
Threads: 101
2
Hate Housework!
Threads: 591
54
Threads: 101
2
great going buddy!
Hate Housework!
Threads: 591
54
26-05-2018, 08:43 PM
(This post was last modified: 26-05-2018, 08:44 PM by Piggy.)
Trying to sort the little things to help me fall in love...
So debadged today as some of them were damaged...exposed a bad paint repair though...but that's no surprise.
Also have fixed passenger window the other day... Got motor on route for RCL fix too...
Fitted decent speakers in the front and rear (from the old GTD days) and some OEM front tweeters...combined with a lovely new(ish) Sony HU which connects via BT to me phone for music/calls. Plus a usb slot for a micro usb stick.
Sounds so good now. Old Fronts were blown badly.
Also found suspension knock that's been getting worse and bugging me... FNS ball joint...totally dead  not sure it likes a ton of torque steer, wide wide tyres and brutal acceleration.
Chasing boost issues.....
(also found a spare gear gaitor from the old GTd which is nice as the lemons one was destroyed. )
Need nice solution to gauge pods and sort RCL...plus get the AC working and I can feel the love coming...
Threads: 101
2
(26-05-2018, 08:43 PM)Piggy Wrote: Need nice solution to gauge pods and sort RCL...plus get the AC working and I can feel the love coming...
how about taking a mould off the dash top?
Hate Housework!
Threads: 591
54
(27-05-2018, 10:01 AM)Magenta Sunset Wrote: (26-05-2018, 08:43 PM)Piggy Wrote: Need nice solution to gauge pods and sort RCL...plus get the AC working and I can feel the love coming...
Funny enough I am considering that... Having it like where the Focus ST does...always liked that
Threads: 101
2
(27-05-2018, 11:26 AM)Piggy Wrote: (27-05-2018, 10:01 AM)Magenta Sunset Wrote: (26-05-2018, 08:43 PM)Piggy Wrote: Need nice solution to gauge pods and sort RCL...plus get the AC working and I can feel the love coming...
also my longer term plan.
Hate Housework!
Threads: 591
54
After much fiddling...found a neat way of fitting a stop screw for the VNT mech. With this and some alterations to the bonnet... Found some more movement and control
More boost to come...
Threads: 47
14
Car Model/Spec: Ford cougar v6. Mk6 Transit
Given 20 thank(s) in 20 post(s)
Danny Wideboy likes this.
I Don't Have A 306.
Threads: 22
0
Given 2 thank(s) in 2 post(s)
Hi Piggy...pleased to see it lives, did you angle tighten the cylinder head bolts? what head gasket...mls or fibre? what brand do you recommend
Threads: 52
4
Car Model/Spec: XSi 16v
Given 83 thank(s) in 81 post(s)
Hi Piggy. I may have got the timeline confused but was the 3rd rebuild in response to the overheating issues? What did you decide was the main cause in the end?
You must know your way around that engine with your eyes shut now!!
Threads: 591
54
29-05-2018, 09:18 PM
(This post was last modified: 29-05-2018, 09:19 PM by Piggy.)
(29-05-2018, 07:20 PM)unclebeast Wrote: Hi Piggy...pleased to see it lives, did you angle tighten the cylinder head bolts? what head gasket...mls or fibre? what brand do you recommend
Check the video sequence if you really keen... ARPs use torque settings
Does anyone use a fibre HG these days!?
(29-05-2018, 08:17 PM)Mighty306 Wrote: Hi Piggy. I may have got the timeline confused but was the 3rd rebuild in response to the overheating issues? What did you decide was the main cause in the end?
It was due to the second catastrophic valve spring failure.
Cause: crap design then crap material used
Threads: 591
54
Threads: 7
2
Car Model/Spec: 106 slo-nad
Given 7 thank(s) in 7 post(s)
Threads: 52
4
(12-06-2018, 06:26 PM)Piggy Wrote: Broke down.
#annoying.
Nothing serious I hope.
Threads: 591
54
I THINK bitron/brown relay.
Coughed and all cut out for a split second. Then 1/4mile later... Just cut out. Wouldn't restart. No LP. Relay buzzing its head off.
Away now till weekend so can't investigate further
Threads: 591
54
Fixed with replacement relay.
Used to keep these relays in stock back in the day
Threads: 52
4
Happy Days!
Threads: 591
54
28-06-2018, 03:31 PM
(This post was last modified: 28-06-2018, 03:57 PM by Piggy.)
Wasn't fix. Turns out it lost an earth somewhere... Much loom digging later... Still no joy. So temporary earth to the ecu case is keeping it going....new loom one day I think, maybe with a new shell...
In other news;
New brakes.
New bigher master cylinder...because, new brakes
Threads: 7
2
Threads: 591
54
Threads: 66
5
Car Model/Spec: 306 Estate - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
Still Living For The 306
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
Threads: 7
2
