15-11-2012, 08:31 AM
How do I tighten my aux belt as the noise it doing my head in.
Aux belt
15-11-2012, 10:57 AM
depends if you got air con or not
15-11-2012, 11:59 AM
Jack it up, wheel off, arch liner out and then look for the tensioner, it will be the pulley which is just bolted to the block, not the crank pulley/pas pump pulley/alternator etc.
Then just loosen the tensioner and move it round so the belts tighter then tighten the not back up. Is it squeeling when cold or constantly?
15-11-2012, 08:59 PM
sounds like it's stretched maybe worthwhile getting a new one
17-11-2012, 12:32 PM
I'm looking at new belts but don't know which one to go for.......
http://www.eurocarparts.com/car-drive-belt Team derv FLAME and CONROD spitters
17-11-2012, 12:39 PM
Take the old belt in buddy
17-11-2012, 12:42 PM
It's still on the car and I have to drive down there to get it.
17-11-2012, 12:59 PM
(This post was last modified: 17-11-2012, 01:04 PM by bigcheez2k3.)
Should be ok to drive without it, you just won't have an alternator or PAS. It's diesel though so once it's started it doesn't use that much power.
I got one from ECP the other day, 6pk1130 didn't fit it though so no idea if it's right. Just looked on service box, I think it depends on what size the pulley is on your PAS pump. 10 5750 WR 01 DRIVE BELT K6 - LE 1102 - UNTIL RPO 07246 WITH PUMP DIAMETER 117MM 5750 TK 01 LONG 1130-K6 - SINCE RPO 07247 WITH PUMP DIAM 135MM |
Belt slapping wildly - belt tensioned - pics added | ginge191 | 57 | 29,080 |
25-04-2013, 09:22 AM Last Post: Mattcheese31 |
