Threads: 102
18
Hello,
I've been told by a peugeot dealer that 306 aerials do not have a seal?
I can't find on on service box either, however I have heard of others buying these seals from peugeot.
As a last resort I'll just silicone it up but for the sake of a few quid I'd rather do it properly, so does anyone know a part number for an aerial seal for a Ph.1 306? Or a print-out from servicebox ideally?
Thanks.
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Never seen a specific seal the unit itself should seal enough, changed mine a while back and never had any issues x
Threads: 465
114
Car Model/Spec: Vauxhall
i cut a thin rubber gasket for mine as it was leaking, it works, no leaks yet
Threads: 151
14
Car Model/Spec: 306 D-turbo
tiger seal has always worked for me
Team Doesn't own a 306
Threads: 87
48
there is no gasket, just make sure the surfaces are clean and don't under or over tighten it . . .
81
Nope there may be a thin bit of rubber but im pretty sure you just need to do the nut up tight enough and it seals anyway.
Threads: 102
18
Yeah I've looked at service box myself and with a peugeot dealer and it does appear that there is no seal.
My current one is leaking a tiny bit, might remove it, reseat it and then silicone.
Thanks!
