Quote for MOT pass repair, is this ok?
Right, the mrs Petrol 306 failed its MOT.
For a loose CV gaiter, they want £17 to sort this out.
The other side needs replacing, they want 9.51 for a CV boot and £50 to replace it.
Front suspension arm has play in a ball joint.. They want £66 for an 'arm' and £50 to fit it.
They also say it needs tracking, £40 to sort this.
All in, inc vat its £265.
Is this reasonable or are they taking the p*ss
http://www.eurocarparts.com/search/61554.../car-parts - £34 for the arm
http://www.club-306.com/topic/21998-how-...-wishbone/ decent guide on wishbone changing
A new driveshaft is cheaper! I got a driveshaft for the 106 with 2 years warrenty for less than a new boot fitted. Tracking is only usually £15 also!
Jubilee clip will also sort a loose gaiter i did this on the large side and it cleared the subframe fine Smile
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
£17 for them to put a cable tie around the boot, lol that would cost you about £100 to fix yourself... Only thing they need to do is the tracking
