Quote for MOT pass repair, is this ok? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Quote for MOT pass repair, is this ok? (/showthread.php?tid=4391) |
Quote for MOT pass repair, is this ok? - cpikey316_ - 22-06-2012 Right, the mrs Petrol 306 failed its MOT. For a loose CV gaiter, they want £17 to sort this out. The other side needs replacing, they want 9.51 for a CV boot and £50 to replace it. Front suspension arm has play in a ball joint.. They want £66 for an 'arm' and £50 to fit it. They also say it needs tracking, £40 to sort this. All in, inc vat its £265. Is this reasonable or are they taking the p*ss RE: Quote for MOT pass repair, is this ok? - vlj - 22-06-2012 http://www.eurocarparts.com/search/615545040/p/car-parts - £34 for the arm http://www.club-306.com/topic/21998-how-to-change-a-front-wishbone/ decent guide on wishbone changing RE: Quote for MOT pass repair, is this ok? - HDIkyle - 22-06-2012 A new driveshaft is cheaper! I got a driveshaft for the 106 with 2 years warrenty for less than a new boot fitted. Tracking is only usually £15 also! Jubilee clip will also sort a loose gaiter i did this on the large side and it cleared the subframe fine ![]() RE: Quote for MOT pass repair, is this ok? - Connor - 23-06-2012 £17 for them to put a cable tie around the boot, lol that would cost you about £100 to fix yourself... Only thing they need to do is the tracking |
