K14 turbo or complete turbo and manifold for 1.9td
Wanted: K14 turbo or complete turbo and manifold for 1.9td
Im starting to think the turbo oil seals may have gone on the hot side so looking for a cheap known good turbo to swap and see if this sorts the problem.
What you got, collection would be better to avoid postage but i know not eveery one will live near me but i can collect from south south east .
Thanks Smile
i've got a whole K14 turbo setup on a manifold and ready to go.
Initially thought the turbo was bust, so changed it for a K03, turned out to be a leaking exhaust fire ring.
But downsize was what i was after - can check shaft play (giggidy) and photograph blades etc. if you like. Smile
I can also, get the turbo to portsmouth/southampton - would be cheaper than postage.
ginge iirc the play in your shaft was fine, and the blades weren't damaged, just thought i'd chuck that in Smile
I have a Bare K14 too with no manifold or exhaust elbow but they are easy enough to swap over Smile
Team Orange Engine Bay
What are the prices you are after?
inlet mani on k14 and t2 is same if theyre off a 306
(20-06-2012, 09:13 AM)Fozzy Wrote: What are the prices you are after?
pm your way
  Gti-6 or d-turbo. Jake 3 3,529 19-09-2017, 11:09 AM
Last Post: Mattcheese31
  Wanted: Turbo upgrade Chris_90 0 1,466 17-07-2017, 09:19 PM
Last Post: Chris_90
  Wanted: turbo diesel exhaust manifold Chris_90 4 3,656 06-12-2016, 01:10 PM
Last Post: Chris_90
