07-05-2012, 05:47 PM
very nice
go rough a idea what your expecting out of it?
Click to see how smokey is doing
----> Project Smokey
darrenjlobb's Project M-TDI Twin Turbo Supercharged Derv Bus
very nice
08-05-2012, 09:53 AM
Parksy87 Wrote:very nice Severe neck-ache I should imagine! The shot with the two snails and the supercharger really sums up this project. Shame I won't be at FCS this year to check it out. Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
08-05-2012, 10:11 AM
And you psoted that again why?
08-05-2012, 11:28 PM
cwspellowe Wrote:YEAHHHHHHHHHHHHHHHHHHHHHHHHHHHH!http://tinyurl.com/6jmxb4s
08-05-2012, 11:31 PM
15-05-2012, 07:41 PM
Not much to update sadly as stuck atm waiting for parts to move it on, but did get turbo oil feeds half sorted the other day, although waiting for some inline filters to turn up atm so cant even finish that.
Made up my own hoses with AN fittings, if anyone is doing custom turbo jobs, this is by far the easiest way of doing this that ive found, fittings for anything in the world are easily avalible, and easy to do yourself... ![]()
| #DervMafia | ![]()
15-05-2012, 07:44 PM
oo00OOhhh shiny stuff!
still keep looking at that engine bay picture and admire it so much!
Phaes 1 GTI 6 - Onyx Black
16-05-2012, 10:12 AM
Looks shit, /thread
pull your finger out Lobb, even I have a working engine now!
16-05-2012, 10:19 AM
[quote="Ben Jay"]
![]() just trying to get my head round this..turbo at the front feeds the turbo at the back which pumps the air into the engine right? but where does the S/C come into things? Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
16-05-2012, 10:27 AM
both turbo's are together, small one gets bypassed when bigger one get onto boost and the output from both goes through the supercharger as a boost multiplier and then into the engine is how I understand it
16-05-2012, 10:28 AM
'Little' turbo at back into bfo-turbo at front into supercharger.
16-05-2012, 10:30 AM
mark_airey Wrote:both turbo's are together, small one gets bypassed when bigger one get onto boost and the output from both goes through the supercharger as a boost multiplier and then into the engine is how I understand it is there somthing like a throttle butterfly involved then to "turn off" the smaller turbo? Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
16-05-2012, 11:29 AM
Think of a supercharger as a compression increaser.
Whatever pressure it has on the inlet, it pressurizes it more on the discharge side. That's why Eatons are called positive displacement superchargers.
16-05-2012, 11:32 AM
Scott Wrote:'Little' turbo at back into bfo-turbo at front into supercharger. Nah as the little one would never flow enough air to supply the BFO one.............. Ben Jay Wrote:is there somthing like a throttle butterfly involved then to "turn off" the smaller turbo? Thats what the bypass is, it diverts the exhaust gasses away from the smaller turbo thus stopping it spooling, again, thats how I understand it anyway
16-05-2012, 05:39 PM
Mark / Ruan are right..
You basically have to imagine is as two systems, saying three just confuses matters... Basically the supercharger sits infront the intake and provides constantly pressure through the rev range, which makes up for the drop in compression, which has the effects of reducing the haze at idle, reduces turbo lag, and when boost from turbos come in, re compresses the air, allowing higher boost levels while holding turbos in there efficiency for longer... it effectively just alters the engines volimetric efficiency for the better, but obviously using up hp doing so...but my old de comp XUD wouldn't even run without it, just chronic haze / smoke.... So the charger just sits there constantly giving pressure / compounding the boost. Then the turbos are setup in a sequential setup, meaning one turbo (the small VNT) is for low rpm, and the big turbo is for mid / top end flow, working in a way that the small one literally gets bypasses (hot and cold side) once the big one is on puff, not like compounding where they both remain online / re compressing air... So basically its a sequentially compounded boost setup, if that makes sence... I made a diagram to try and show what im on about:
| #DervMafia | ![]()
16-05-2012, 05:49 PM
mspaint.exe ftw
| #DervMafia | ![]()
16-05-2012, 06:04 PM
that still blows my mind, gunna take me a while to get my head around that one!
16-05-2012, 06:12 PM
It's just taken me a few minutes to work that out haha. Very clever!
16-05-2012, 08:25 PM
It's alot like a vapour compression cycle with a 3 phase inverter driven motor setup! Very clever indeed!
:wink: ![]()
16-05-2012, 08:39 PM
So where does the flux capacitor go?
16-05-2012, 09:05 PM
So to simplify things the super charger is "always on" being spun by the pulley.
This is fed by both turbos. Once the smaller turbo has run out of puff it is bypassed and the bigger turbo kicks in feeding the super charger with more air. The super charger in turn increases the pressure meaning more air is being forced in. Right? Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
16-05-2012, 10:07 PM
Looks awesome! Haha just imagine taking that into a peugeot dealership for a service they would be like ye a 1.9 Turbo Diesel. *Opens bonnet* WTAF
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
16-05-2012, 10:33 PM
Maybe I should one day, and ask if I can video some clips for "youtube" lol!
| #DervMafia | ![]() |
| Peugeot 309 d turbo project | adampug | 30 | 24,265 |
04-12-2016, 10:03 AM Last Post: adampug |
| Project Facelift Berlingo D Turbo | Jamieh2013 | 11 | 9,913 |
21-03-2015, 05:01 PM Last Post: Jamieh2013 |
| chris_90 106 derv project xsi rep, turbo NAD ;) | Chris_90 | 428 | 335,104 |
06-04-2014, 11:50 PM Last Post: Danny2009 |
