Spinning TRE ball joint.....HELP!!
samass Wrote:placcy bag it to stop the rain getting in. hot air gun will do the trick, just protect the shaft so that doesnt heat up too
Meh...Im not going outside again tonight, just showered and got my dirty/wet clothes in the wash.....
How can I protect the shaft? Confusedhock:
Also, do I have to be careful of heating up the bearing? Surely that wouldn't be good for it?
#32
Tom, havent read this properly, but you were trying to replace the driveshaft? Why are you trying to take the TRE off? all you need to do is pop the bottom ball join off and then just swing the hub/strut with the TRE still on...
gotta make sure you wrap up, might get a disease Wink
JK, i used a socket, just enough to deflect the hot air. wouldn't worry bout the bearing, you wont get it hot enough to wreck it. might be worth greasing it up again after if you an tho, just to be safe.
#34
Connor Wrote:Tom, havent read this properly, but you were trying to replace the driveshaft? Why are you trying to take the TRE off? all you need to do is pop the bottom ball join off and then just swing the hub/strut with the TRE still on...
You can't move the strut anywhere near enough with the TRE still on....I tried.....
#35
you can if the shaft is out at the hub end, but that stuck, and youd already got the tre spinning, so whatever lol
#36
You can on a 306, I did it earlier :dance:
Connor Wrote:
Toms306 Wrote:You can't move the strut anywhere near enough with the TRE still on....I tried.....
Probably...but due to the lack of PAS on this, the tre is like halfway up the strut....can't even pop the bottom ball joint off with the TRE left on! Doh
#38
I bet i could...
Connor Wrote:I bet i could...
You probably could.....but I couldn't. Tongue
#40
For f*ck sake.....car fell off the stands last night, think I should probably give up tbh. :/
[attachment=0]
Good job you weren't under it pal!
Has it done any damage?
#42
Shit, how did it manage to fall off though? Lol.
Connor Wrote:You can on a 306, I did it earlier :dance:
[/quote]
Yes you did, we had slight leakage though lmao
[Image: siggy1.jpg]
#44
Matt Wrote:Shit, how did it manage to fall off though? Lol.
Probably the wind, was right windy last night, or the stand sunk into the ground at one end.
Take the disc and caliper off, give yourself some more room.
#45
unlucky dude, get a sledge on that driveshaft while it's on the ground lol
looks like theres just enough room to get a scissor jack under it?
#46
Low entry jack FTW!! Got it up eay enough and the stand bent 'some peice of metal' underneath which JUST saved the brake lines from being broken lol. I'll stick up a pic of the stand in situ lol....gimme a minute....
#47
Can pic the corner of one of those up if you try, I did it with the back of my old one.
#48
[attachment=0]
bigcheez2k3 Wrote:Probably the wind, was right windy last night, or the stand sunk into the ground at one end.
Yup both.
The thing is though, this is how I was hoping to leave the golf while I fix it.....definitely gotta rethink that now! :o
Update on this, I've just broken a bearing puller trying to get this bastard out! Tried heat as well and still nothing.
Caliper and disc are off for the puller so now just looking for a complete strut to swap on. f*cking french shit....not I remember why I went German! Bolts dont snap and round so easy, everything on the golf is clean whereas its covered in oil and grease on the pug and everythings seized to f*ck on here too.
#50
bigcheez2k3 Wrote:Can pic the corner of one of those up if you try, I did it with the back of my old one.
Tbh you'd probably break it trying to pick it up.....I gently leant on the wing yesterday to sit down (getting old, need something to lean on lol) and the whole wing pushed in. lol No wonder pugs dent so bloody easily, they're made of tin foil, I often lean on the golf wing with no problem. :?
#51
lol
so, you kept a car on axle stands over night, in the wind and rain, on sand/slush and now let me get this right, you're surprised this fell over?! lmao
ginge191 Wrote:lol
What other choice did I have though? :roll:
#53
Well you were stupid for having the stand so high on an uneven surface... probably have been alright if you didnt jack it up so high or had it on solid ground
I dont have solid ground to use unfortunately.......trying to get the 'rents to have a concrete driveway lol!!
And I had to get it high to get under there.....
It's been alright like that before with the nice heavy golf giving it some downforce.....and I did rock the pug before I left it and it seemed fine lol...obviously it wasn't. But meh, thats not really an issue now.
#55
Iirc Tom's driveway is sloped so it was probably high to keep the car level and less likely to erm...fall off the stands lmao
#56
Haha, well that, and high to drain all the gearbox oil out.....with the peices of metal too. lol
#57
Should stick a nice lump of flat wood under it Wink if you haven't got solid ground... Make some Wink
That might work on grass but the wood just slips on gravel, I've tried. Sad
#59
Paving slab?
#60
bigcheez2k3 Wrote:Paving slab?
Yeah that might work. I've only got one spare though lol.
  Ball joint/ Hub to strut pinch bolts Uberderv 7 5,361 04-01-2018, 11:40 AM
Last Post: Mighty306
  fitting a front suspension ball joint impotentials 3 3,715 29-10-2016, 05:46 PM
Last Post: Poodle
  Bottom ball joint sizes Xsikid 4 3,574 04-05-2016, 05:45 AM
Last Post: Paul_13
