Lexia 3 Citroen Peugeot Diagnostic Car scan tool
I was looking at the Lexia 3 Citroen Peugeot Diagnostic Car scan tool. This one seems to be one of the best to go for?
I was thinking it might be handy to have for my 306 hdi. It would be cheaper and save time than paying for the garage or changing diffrent parts etc.
So does anybody know about these?
Also any others etc?
Very useful tool. I love mine. Look in the guides section. I'm currently writing a guide on how to use it.
Niall Wrote:Very useful tool. I love mine. Look in the guides section. I'm currently writing a guide on how to use it.
Thanks sounds like a tool worth having then.
I paid 100 delivered for mine and I've used it on several cars. Not much to play with on the 306 except for programming keys, alarms, new ecus ect but on other cars like 206s, 307s it's very helpful!
The live data read out is also extremely good as it gives it to you in the raw values instead of dressing it up as other crap like most readers do.
The live data read out that will that show any problems the car having then to pin point were etc?
Thats handy to know it works on older cars and newer cars as well.
Welshy_Pete Wrote:The live data read out that will that show any problems the car having then to pin point were etc?
Yep. Gives out voltages from sensors, injection timings ect. Useful if you know what your looking at but a quick 5 minute google explains most of it in basic detail.
it looks like its from the states but...
http://www.soleobd.com/Lexia-3-Lexia3-V4...-2434.html
[Image: siggy1.jpg]
I got mine from amazon. Seller was very helpful with getting the software set up (wasn't the quickest delivery though)
got mine from ebay after the second attempt
1st attempt ended when ebay withdrew the listing because of the pirated software
Ive just bought a lexia 3 for £80 including p&p.
Hi. How are you getting on with your lexia 3? Is it as good as the write up suggests? As in can it truely read ALL ECU's including the ABS module / ECU? Sounds like a bargin if it can, £40 for a one off diagnostic or £80 to diagnose as much as I want, as many times as I want, on all Pug's I can ever see me owning (although none beat the shape of the 306) Smile
Just recieved my Lexia 3 and software. The software is called DiagBox and says it does citroen as well as Peugeot, the Peugeot software is Peugeot Planet [aka PP2000] and gives a choice of most cars they made and make that are likely to be on the road and have some level of diagnostic. I've only used on a Phase 3 306 but noticed 205's, 309's, 406's listed. It does read all ECU's in the car and even attempted to read the auto ecu which my car doesn't have what with being a manual. It accuratly reads stored and current faults from what I tested, and even resets the ABS ecu.
Its a little tricky to setup and being given the wrong logon code didn't help, but a quick search found the right code.
In short I would highly recommend getting one of these, it was very worth it for me.
I have been meaning to buy one of these for awhile now.
I was looking at this on on Ebay Item Number: 160942429192.
Is it worth buying from here or from a different source?
Hi, all
Has anyone got a user guide or put one together for using these Lexia3 packages sold on ebay?
Niall hass one in guides sectionn i think
Now the lexia 3 diagnostic scan tool has been updated to v48, and the diagbox updated to 7.53, so it supports Peugeot 307
(08-04-2015, 06:43 AM)tieoghk3 Wrote: Ive just bought a lexia 3 PP2000 for £43 including p&p
Which bits from the site would I need for a 98 gti 6? Ta
(25-07-2012, 11:14 PM)jay8086 Wrote: Just recieved my Lexia 3 and software.  The software is called DiagBox and says it does citroen as well as Peugeot, the Peugeot software is Peugeot Planet [aka PP2000] and gives a choice of most cars they made and make that are likely to be on the road and have some level of diagnostic.  I've only used on a Phase 3 306 but noticed 205's, 309's, 406's listed.  It does read all ECU's in the car and even attempted to read the auto ecu which my car doesn't have what with being a manual.  It accuratly reads stored and current faults from what I tested, and even resets the ABS ecu.
I'm struggling to setup the software. The code and which bloody icons to click on and which folder on each cd.
I do a lot with computers and its a bit of a nightmare to even get the software on or running. I'm not sure where to go from here.
at the initial the best Quality one is sp08-c,now it has been replaced,new one is VXSCAN OBD Version Lexia3 PP2000 Diagbox Firmware 921815C Lexia 3 PSA Diagnosis Device
http://bit.ly/2trv2WU
  installing PP2000 and Lexia welshpug 22 12,092 01-07-2016, 05:18 PM
Last Post: welshpug
  diagnostic reccomendations... Piggy 5 3,129 16-01-2015, 08:40 AM
Last Post: Toms306
  Using Lexia 3 Guide??? Jammy666 0 2,289 18-04-2013, 04:49 PM
Last Post: Jammy666
