25-04-2012, 08:19 PM
where is the gear drain and filler located on a 1995 1.9DT
is it a level fill system
Thanks
Thanks
Gear oil change
is it a level fill system Thanks
25-04-2012, 08:25 PM
Drain is on bottom of tranny, can fill from top or from level plug, which is located in passenger side wheel arch, the larger of the bolts on the end...
| #DervMafia | ![]()
25-04-2012, 08:31 PM
Would filling from level plug be enough oil?? or will i have to fill from the top?
Regards
25-04-2012, 08:51 PM
Lol filling from the level plug would generally indicate that we its full to there, its level with where its meant to be
| #DervMafia | ![]()
25-04-2012, 08:55 PM
Cheers
is it best to replace the washers on the drain and filler bolts when changing the oil?
25-04-2012, 09:36 PM
306 d turbo Wrote:Cheers It's probably advised, but personally I've never changed them. If they leak its not a massive job to replace them.
| Gear change noise | 306__xrdt | 2 | 2,341 |
01-02-2013, 10:56 AM Last Post: 306__xrdt |
| Gearbox gear change? | Ben | 6 | 4,854 |
11-07-2012, 08:22 PM Last Post: strictly_perv |
