HDi Dyno Results BIBLE
#91
Before I buy another one is this the right sensors the 1800bar one febi bilstein 45187 cross-referenced from OEM no:9658227880?? Thank you in advance.
#92
My results in a hot day with Pro-Steve's limited torque Stage 2:
145 CV and 253 lb/ft @18Psi/1,2 Bar
FMIC, de-EGR and de-CAT
[Image: FnwKsUO.jpg]
Have to adjust the boost a little up.
#93
Bon resultat! Good result!
Diesel parts designer:
-HDi/1.9td and 2.1 XUD11T forged HBeam conrods available in stock
-Custom ARP Head Studs kit available for HDi/1.9Td and 2.1 XUD11T
-Aluminium damper pulley for Hdi/Xud11T
-MFS prechamber for XUD
Ask for delivery
#94
(24-06-2018, 11:50 PM)Biggen Wrote: Bon resultat! Good result!
What are your specs?
What more specs do you want? Huh   It's a HDi 90 with near to 250k km on the clock and the rest I think I've put it on my post!
#95
Specs are in the post with power printout
[Image: lJjSEOI.jpg][Image: 49x0UfQ.jpg]
Gtb2056v with problems in n75 cycle maps
224hp (can be more with better turbo regulation maps)
Big pump
8-hole nozzles
All internal stock
https://youtu.be/EPffYMQmEzs
#97
By the power of Google Translate ....!
Big pump
8-hole nozzles
All internal stock
#98
What has been done to the head?
What injectors??
(06-07-2018, 06:40 PM)Piggy Wrote: What has been done to the head?
What injectors??
Stock head and cummins nozzles with stock injectors
  My Dyno Results JTaylor2005 4 3,728 02-04-2016, 01:32 PM
Last Post: JTaylor2005
  HDI rolling road results the milkman 14 10,865 20-03-2014, 06:49 PM
Last Post: pugbug
