09-04-2018, 09:15 PM
Before I buy another one is this the right sensors the 1800bar one febi bilstein 45187 cross-referenced from OEM no:9658227880?? Thank you in advance.
HDi Dyno Results BIBLE
21-06-2018, 10:59 PM
My results in a hot day with Pro-Steve's limited torque Stage 2:
145 CV and 253 lb/ft @18Psi/1,2 Bar FMIC, de-EGR and de-CAT ![]() Have to adjust the boost a little up.
Bon resultat! Good result!
Diesel parts designer:
-HDi/1.9td and 2.1 XUD11T forged HBeam conrods available in stock -Custom ARP Head Studs kit available for HDi/1.9Td and 2.1 XUD11T -Aluminium damper pulley for Hdi/Xud11T -MFS prechamber for XUD Ask for delivery
27-06-2018, 10:50 PM
Thanks given by: Biggen
28-06-2018, 04:01 PM
(24-06-2018, 11:50 PM)Biggen Wrote: Bon resultat! Good result! Specs are in the post with power printout Wishes for more power...
05-07-2018, 11:49 PM
(This post was last modified: 06-07-2018, 07:33 AM by bixigu.
Edit Reason: Add video
![]() ![]() Gtb2056v with problems in n75 cycle maps 224hp (can be more with better turbo regulation maps) Big pump 8-hole nozzles All internal stock https://youtu.be/EPffYMQmEzs
06-07-2018, 06:03 AM
By the power of Google Translate ....!
06-07-2018, 06:40 PM
What has been done to the head?
What injectors?? Wishes for more power...
06-07-2018, 07:00 PM
| My Dyno Results | JTaylor2005 | 4 | 3,562 |
02-04-2016, 01:32 PM Last Post: JTaylor2005 |
| HDI rolling road results | the milkman | 14 | 10,487 |
20-03-2014, 06:49 PM Last Post: pugbug |
