Typicall not starting
So the battle bus isnt starting. Drove it only the other day which makes it annoying.
Eml is on, used a micky mouse reader to get the following codes.
P0500 - speed sensor
P0380 - egr
P0403 - glow plug circuit a
- In take pump is priming a ok.
- fuel upto the injectors.
- cranking at a good pace.
- cam sensor plug reterminated after insulation discovered broken on wires
- burnt pin discovered on brown fuel relay
- possible new location of fuel and glowplug relay could be damp.
- battery disconnected for ten mins, no change
- ecu codes wiped. 380 and 403 return.
- top plug on hp pump (think stop solonoid) damp, dried out and sprayed with wd
Sent from my BLA-L09 using Tapatalk
Still Living For The 306  Rofl
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
No ideas??? Not even a spit ball by anyone
check live data with diagnotic gear
check fuel pressure request vs actual and cam sync
GTI6 Info
does it crank over?
Hate Housework!
I've had similar starting probs recently. Turned out the filter was totally clogged, new filter and it started reet up.
pump has to see 280 bar for injectors to think about firing.
