Typicall not starting - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Typicall not starting (/showthread.php?tid=36745) |
Typicall not starting - dr_jekyll - 14-04-2018 So the battle bus isnt starting. Drove it only the other day which makes it annoying. Eml is on, used a micky mouse reader to get the following codes. P0500 - speed sensor P0380 - egr P0403 - glow plug circuit a - In take pump is priming a ok. - fuel upto the injectors. - cranking at a good pace. - cam sensor plug reterminated after insulation discovered broken on wires - burnt pin discovered on brown fuel relay - possible new location of fuel and glowplug relay could be damp. - battery disconnected for ten mins, no change - ecu codes wiped. 380 and 403 return. - top plug on hp pump (think stop solonoid) damp, dried out and sprayed with wd Sent from my BLA-L09 using Tapatalk Typicall not starting - dr_jekyll - 15-04-2018 No ideas??? Not even a spit ball by anyone Sent from my BLA-L09 using Tapatalk RE: Typicall not starting - cully - 15-04-2018 check live data with diagnotic gear check fuel pressure request vs actual and cam sync RE: Typicall not starting - Magenta Sunset - 15-04-2018 does it crank over? RE: Typicall not starting - Uberderv - 15-04-2018 I've had similar starting probs recently. Turned out the filter was totally clogged, new filter and it started reet up. RE: Typicall not starting - mr_fish - 16-04-2018 pump has to see 280 bar for injectors to think about firing. |
