Parcel shelf speakers
What’s the consensus on them? Obviously a shit place to have speakers, mine seem to vibrate and make horrible noises. Get rid of them? Replace with low powered items?
I want a OE parcel shelf so won’t be building any MDF heavy weight things! Car is currently getting sound proofed, using a half decent pioneer head unit, component fronts and a active sub.
Thanks,
Ali
i have kenwoods in the front doors, Alpine 6x9's in the parcel shelf and an Alpine sub in the boot, always pop 6x9's on the shelf, personally i think they can work well Smile
Could always replace with new speakers in the oem positions.
Check Out My Build Threads // Puglet Build
The rear parcel shelf ones are pretty shallow. Youd have to cut the bottom of the mounts out to fit anything bigger in unless you could space them out somehow. I usually find ramping the audio back on the standard rear speakers sounds good enough for me.
bin them off and the radio
turn up the volume the engine sounds sweet at 11
GTI6 Info
dont think the dw10 will go to 11 more than once...
What shelf have you got. I tend to find the “stealth” shelf has better quality speakers in. This may jist be as its newer though.
My car seems to have had some more powerful speakers fitted to the parcel shelf by a previous owner.  They sound pretty good TBH - no buzzing.  (I've always thought the standard 306 sound system was OK too).
The replacement ones are heavy though & the boot struts don't seem to be up to the job of taking the weight so the boot regularly cracks me on the head!  Must look in to some better struts Smile.
Get decent components fronts. Disconnect the rears. They don't sound great. Only reason I can think of for having rears is to even out the volume for rear passengers. But even then the sound is coming from behind. Not good.
Get decent fronts, creating a good sound stage. Also the head unit is pretty average. A new HU will make a big difference.
Some good advice thanks, I’ll fit some cheap standard size after market items, have components up front. It’s a standard phase 3 stealth shelf with the baskets!
6x9’s would be nice as they are dirt cheap it seems but won’t fit in OE location!
And I would never get rid of the stereo! Listen to music on every journey, a roattly 200k HDI isn’t music!
(07-11-2017, 07:38 PM)allye Wrote: Some good advice thanks, I’ll fit some cheap standard size after market items, have components up front. It’s a standard phase 3 stealth shelf with the baskets!
I dont mind listening to my rattly 220K HDI means i can tell when somethings broken  Rofl
Honestly dude after reading a few threads get some decent front door speakers and sack the parcel shelf ones off. Im gonna give them method a go and see where im at. If worse comes to worse i can always just plug them back in  Rofl
In the rallye ive got focal 165vs in the front with a decent head unit. However even though its caged with the rear seats removed i still keep the parcel shelf in with the rear speakers as it adds a lot to the sound!
yes it's true you need to cut the parcel shelf Smile
you could probably space the rear holders out. maybe ill look into 3d printing spacers.
Alpine Type E 6.5" speakers are my choice usually with Pugs...
Very very nice and shallow too, so fit in OEM places.
  Parcel shelf Jimer64 2 4,088 15-06-2020, 06:09 PM
Last Post: Jimer64
  door and parcel shelf speakers Dramsay1984 3 3,264 01-09-2014, 08:36 PM
Last Post: Iceman299
  Upgrading parcel shelf speakers C.A.R. 8 5,313 02-05-2014, 12:23 PM
Last Post: Kwik
