Gearbox Questions
Thumbs Up
Going to change the clutch on a 306 hdi due to the unbearable slippage in 3rd/4th/5th
what would you guys suggest?
LUK or Valeo?
I also have the option to get it Kevlar lined ? is it worth the price and does anyone have any experience with a kevlar clutch?
also, while the gearbox is off is there any parts that need replaced? eg clutch fork bushes ect?
thanks guys  Dodgy
oem luk or valeo will be fine for a stock engine
consider an upgrade if you're going to run a remap.
replace nylon fork bushes and cable - and poss the fork if it doesn't clean up well.
check the input shaft seal on the gearbox too, as piece of cake to replace while its off
(19-07-2017, 06:24 AM)zx_volcane Wrote: oem luk or valeo will be fine for a stock engine
Currently stage 1 atm and it is slipping bad, but the car does have a 134k with no reciepts of changing the clutch ever lol.
will i genuine peugeot cable? or does it matter? and is there part numbers for the nylon fork bush and input shaft seal?
thanks.
Stage 1 will be fine on a standard clutch. LUK or valeo doesn't really matter. Pattern parts are fine so long as you don't buy cheap crap.
Bush part numbers in previous post ....
http://www.306oc.co.uk/forum/showthread....ork+bushes
  Few questions on Axle and Gearbox Marcus1991 10 8,832 14-02-2013, 10:40 PM
Last Post: Marcus1991
