Oil feed sizes
Oil feed sizes
Need to know the thread sizes for a gt15 chra and the size on the block for the high pressure turbo feed.
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
garrett website??
Info in my project thread somewhere
Got to the chra is m10x1.0 so far.
Any idea on hdi block size tho?
Justin_306DTurbo
M12x1.25 or M14x1.25 - try a wheel bolt in it lol - it's the same from memory. Might be an M14 though.
Found an xud is apparently m16x1.5. Spose block feeds deffo easiest to check from underneath
Justin_306DTurbo
sounds about right, the oil pressure warning light is m16x1.5 too.
Adapters are only £4 a pop so not exactly much to lose. Just gotta decide on pipe size then. Either an-4 or an-8 finding most garret AN kits are an-4 so guessing thats the kiddy. Prob work better over the distance too to reduce pressure drop
Justin_306DTurbo
