Threads: 23
Car Model/Spec: GTi 6
Given 1 thank(s) in 1 post(s)
As the title says I'm curious as to what sizes people are running in their rear beam and where they've acquired the larger sizes from as they are quite pricey from pug1off.
Also is there anyone on here that does custom beam builds?
Thanks!
Threads: 42
28
there's a few of us doing beams, what are you using the car for? that'll give you an indication of the size if bar required.
21mm is readily available from estates or xsaras, (standard is 20mm) pts spec for tarmac was 23mm.
dont forget that the bigger the bars and the harder you work them the more you need to spend on dampers.
Threads: 23
The car gets used a lot on B roads but also I'd like to do a few track days with the car.
Threads: 42
28
Probably best at 21mm then with the standard 24mm arb.
if it was pure track id go bigger arb
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
21-05-2017, 07:09 PM
(This post was last modified: 21-05-2017, 07:09 PM by Stef205.)
Ive fitted various sizes to peoples over the years, from standard 20's upto 23' and 24's but most go for the common 21's out of a xsara beam. Arb's again ive fitted from 24mm upto 32mm all depends on the planned use, but as said bigger bars will require hard and more expensive shocks to cope.
Threads: 23
Thanks for the advice, who on here does beam rebuilds and how much?
Threads: 23
21-05-2017, 08:09 PM
(This post was last modified: 21-05-2017, 08:09 PM by Chris HDI.)
Thanks Cully! I'll keep Stef in mind
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
running 21mm tb and 24mm arb - perfect for fast rd imo
Threads: 42
28
22-05-2017, 07:46 PM
(This post was last modified: 22-05-2017, 07:48 PM by welshpug.)
beam will go straight on, same floorpan.
camber and toe are quite different though most wont noticed it.
trouble is with 100% of the beams out there, they're all worn out unless they have receipts for a rebuild by someone reputable.
Threads: 23
Thanks Welshpug, think I'll just acquire some VTS TB's and get a 306 beam rebuilt, I don't want to mess about with different toe and camber, I know people have machined in negative camber to the arms which is something I may look into in the future.
Threads: 371
29
Car Model/Spec: ford fiesta
if youre gonna find some VTS bars also look at late 306 estates as they have 21mm torsion bars on that are the same
Threads: 10
Car Model/Spec: 306 GTi-6 Blaze
Country:
I have a complete VTS beam and dampers, transformed the handling! Although my old beam was pretty knackered...
Threads: 23
I appreciate all the advice lads!
