Vivaro camper Van conversion
Im so glad i raised my concern as I have just been out and measured some voltages
from Chassis to Neutral i could measure 110volts
from chassis to live i could measure 110volts
hmm that would give you a nasty tickle
so I have now installed a link on the Inverter supply neutral to earth/chassis
this has given me an earth path via the van chassis
taking the same measurements again they were
from Chassis to Neutral i could measure 0volts
from chassis to live i could measure 220volts
I am a lot happier now the van will be a lot more safe running the inverter
and as an added bonus
the socket tester is ticking all the correct box's
before it was showing NO Earth!
[Image: 20170404_171940.jpg]
GTI6 Info
the final part of the electrical jigsaw turned up today, the 12v control panel,
which is now all wired in and working
only thing left electrical now is to wire in the Tap and pump for the water
until i want to change or add stuff!
[Image: 20170406_143901.jpg]
and the rats nest behind the panel
[Image: 20170406_143944.jpg]
GTI6 Info
When's the remap then?!
Makes sense you're a sparky now, getting your head around all that.
suddenly the roof colour makes sense Big Grin
[Image: 20170406_203120.jpg]
[Image: 20170406_201748.jpg]
[Image: 20170406_201735.jpg]
[Image: 20170406_201724.jpg]
GTI6 Info
coming along nicely this cully
hah, party bus
time for cupboard doors
had to do some thinking on the two large lower doors as i wouldnt be able to swing them open with the bed in the way
so i made them into lift off panels the very top one hinge's upwards
no handles yet!
[Image: 20170409_122056.jpg]
[Image: 20170409_122116.jpg]
[Image: 20170409_122206.jpg]
[Image: 20170409_124538.jpg]
[Image: 20170409_141256.jpg]
[Image: 20170409_141311.jpg]
GTI6 Info
Top job , really coming together
what will be your plans for water & waste tanks?
Hate Housework!
(09-04-2017, 06:21 PM)Magenta Sunset Wrote: what will be your plans for water & waste tanks?
done Wink
plumbing done
still need to cut the dropout vent through the floor
think i will be getting some smaller water containers too,
and not where i would like the bottle but no choice really
[Image: 20170409_180844.jpg]
GTI6 Info
Flatpack Rock n roll bed can you see it I can't yet?
I want a 6ft by 46" bed is to fit within a 800mmx800mmx 46" area
wish me luck
[Image: 20170411_192410.jpg]
GTI6 Info
fricken hell i dont look at this thread for a while and boom its had loads done!! you dont hang around sir
pondering beds, seats, fold out shit today i came up with a plan!
remember the breif from the last post!
"I want a 6ft by 46" bed is to fit within a 800mmx800mmx 46" area"
so am going to attempt to make it
if it works or even fits will be a miracle!
but here go's for shits and giggles!
dont rely on the measurments if you use this idea as it was flexible ish Wink
[Image: img20170412_20325224.jpg]
so i started cutting and welding
[Image: 20170412_173004.jpg]
checked the basic 6ft x 46" frame would fit
[Image: 20170412_172846.jpg]
then started adding the fold points
[Image: 20170412_180734.jpg]
End of play today i have got a welded 6ft bed frame that needs hinges and cutting also requires altering to fit wheel arch profile when folded
[Image: 20170412_192926.jpg]
on thing i have suddenly realised a SWB Vivaro with a 6ft bed dont leave a lot of room!
[Image: 20170412_200913.jpg]
GTI6 Info
Double mattress slung in the back of a van FTW.
Rofl Rofl Rofl
But seriously,  as Phil said.
Good work man, it's coming on very well.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
Swivel seat's on the plan cully?
(13-04-2017, 10:28 AM)Lwilliams Wrote: Swivel seat's on the plan cully?
yes it will give more room Wink
Hmmm well that failed!
time to look at something else
the majority of the steal is folded into the wheel arch, may of worked if it was narrower
currently sat looking at Futons
[Image: 20170413_183019.jpg]
GTI6 Info
It might fit if you de-cat it?
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Bed MKI cut up to make Bed MKII
I am happier with this one as i can open cupboards and have more storage under the bed
Smile
[Image: 20170417_160214.jpg]
[Image: 20170417_160116.jpg]
GTI6 Info
folded up bed frame
[Image: 20170418_183726.jpg]
unfolded bed frame
[Image: 20170418_183811_1.jpg]
lift up rear section to create bulkhead for transporting larger items
[Image: 20170418_183920_1.jpg]
GTI6 Info
half of infill done on the bed before work
nice use of scrap roll cages for the wire infill Wink
[Image: 20170422_131243.jpg]
GTI6 Info
thought id best make an effort in some curtains as we are going away in the van next weekend
side windows have some fancy stretchy curtains and the front cab has a temporary pole between the grab rails with a large curtain for privacy
works quite well Smile
[Image: 20170503_193732.jpg]
[Image: 20170503_193804.jpg]
[Image: 20170503_194940.jpg]
[Image: 20170503_195020.jpg]
[Image: 20170503_195026.jpg]
GTI6 Info
just back from a week driving around Wales, found the Van to be well under-powered on the welsh hills so got it on some diagnostic machine to find i have a dead MAF sensor,
£100 Later the van is a different animal drives so much better
symptoms were lack of power bellow 2500rpm always changing gear to chase the rev's where the power was
No fault codes logged only visible on live data on a drive MAF values not changing
anyway great week away lovely weather
we cheated a little as we booked a Sun holiday short break so stayed in a static home Wink
off away again this weekend East Sussex should be fun Big Grin
[Image: 20170508_140713.jpg]
[Image: 20170510_131520.jpg]
GTI6 Info
This is epic, great work cully
have been looking for something to turn my faded grey/black plastics back to black
after much searching I think i have found something better than peanut butter and cheaper than any car stuff in a tin
just mask up and paint on, took around 3 coats to go from grey to black the finish is excellent no brush lines or shading not sticky nor does it rub off
at 39p a bottle cheap as chips too
what do you think?
and what do you think it is Im using
[Image: 20170523_115658.jpg]
GTI6 Info
Wow, 39p and it looks great.
I haven't clue what it could be.
How did you hear about it?
Well, my guess with the chips reference and cost it would be vinegar.
found it by trawlin the net like most things
emptyed the bottle into a pot then used a paintbrush to apply it Wink
GTI6 Info
Genius! Will be good to know how it lasts as lots of black plastic on my phase 2's is looking fairly shabby.
onto Bed MK3
[Image: 20170525_112644.jpg]
[Image: 20170525_131852.jpg]
[Image: 20170525_131837.jpg]
GTI6 Info
[Image: 20170525_155442.jpg]
[Image: 20170525_155405.jpg]
GTI6 Info
  Danny's MK5 Transit camper. With added 508d content. Transit for sale. £1500. Danny Wideboy 60 45,205 06-01-2019, 02:16 PM
Last Post: Niall
