Oil brether woes
Oil brether woes
With the gt2052s fitted she began to pull the oil from the rocker cover into the inlet so i dumped the breather off to atmostphere.
I have no oil in my inlet pipes nor cooler.
Exhaust does not smoke any colour (nor does it soot unless the mafs unplugged).
Yet she consumes 500ml ever 2/3 weeks.
I believe it all to be coming from the rocker brether as im leaving faint rainbows of oil in my yard at work and the inside of that pipe is thick with oil.
Kinda stuck here. Its been suggested to me that the crank brether is possibly blocked and others say rings. Ive been told to check this pipe by a guy at work at also been told to have a spare as they go brittle
[Image: 0932a7bfb332ad6f94cb553c0d21fc63.jpg] is he pointing me arong the right lines??
Any other thoughts please?
Also to add shes lifted the dipstick in the past
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Almost sounds like your rings
I had the same turbo with the breather linked into the air intake and I had no oil being drawn through at all
(01-02-2017, 02:05 PM)Paul_13 Wrote: Almost sounds like your rings
Ahhh fair enough.. was my biggest fear but will run her into the ground then
Not even worth attempting that pipe?
Justin_306DTurbo
if you're rings are gone enough to burn 1/2 litre of oil every couple of weeks you'd know about it.
you'd get constant smoke from the exhaust as its burned.
(01-02-2017, 03:11 PM)zx_volcane Wrote: if you're rings are gone enough to burn 1/2 litre of oil every couple of weeks you'd know about it.
Its not burning. Coming out the brether
Justin_306DTurbo
well again, if you're rings are knackered enough to pressurise the crank and have oil escaping your breather - stick your thumb over breather and give a rev from idle - will soon know if its pressurising.
mind your dipstick shoulda flown out by now ...
(01-02-2017, 03:59 PM)zx_volcane Wrote: well again, if you're rings are knackered enough to pressurise the crank and have oil escaping your breather - stick your thumb over breather and give a rev from idle - will soon know if its pressurising.
Dipstick has pushed up but that was due to the breather filter getting blocked. Got it piped down to the driveshaft and iy god covered in crap.
So no it dosnt usually push the dipstick.. only in extreme circumstances
Justin_306DTurbo
sounds more like a leak from somewhere then, won't harm changing the breather hose
(01-02-2017, 04:52 PM)zx_volcane Wrote: sounds more like a leak from somewhere then, won't harm changing the breather hose
I'll give that a crack then. Been told to refit a brether filter and get the brether out from under the car
Justin_306DTurbo
  HDI starting woes.... cully 5 3,975 15-04-2018, 08:53 AM
Last Post: Mighty306
  HDi woes vlj 4 3,239 24-05-2013, 05:49 AM
Last Post: Poodle
