Matts wagon
Matts wagon
Right so I thought it was about time I got a project thread up for this.
Started off with one very iffy swap.
I swapped my BMW e46 for this 306 estate
It came with xxr wheels, lows and exhaust
[Image: 922B72AF-1737-47C3-B106-F34B904062AC.jpg]
[Image: 1D66EBCC-B686-48E7-864E-A20BF69D55FE.jpg]
[Image: 6A702BF8-A3AB-44E8-A69B-1CD010C020EB.jpg]
[Image: 73BA3946-25B9-49C2-8FFB-D61537916B90.jpg]
So the guy sent me pictures, I loved it straight away. Ended up with it the same night. Had several keys, 1 that opens the car but doesn't start it, one that opens the doors and starts it, and then another that only opens doors
[Image: D46D6C2C-B64E-43B6-B056-A1BE55963D70.jpg]
[Image: 68825E83-0C45-4359-82EE-5337CE71AD7F.jpg]
[Image: 37D70ACA-19C7-442F-91F1-1A31B11CA056.jpg]
So after picking it up, frame banging it onto the ferry, my opinion is low filthy and scrapes f*cking everything
[Image: 34384684-4BE8-4D62-ACE0-DD0033197017.jpg]
So first things first, I swapped the black masks and badge from the rallye, made it look a little nicer. I bent the dent back out using the scissor jack, don't care what it looks like as it will be replaced sometime.
[Image: F252AB02-01F0-4CE9-853A-6B3CF9CCDCE0.jpg]
Next up was changing the steering wheel over from the gross 4 spoke leather, to the momo race wheel, and swapped out the shitty gearknob for something aftermarket I got for free
[Image: 7040C14A-A550-4806-A86C-630775597F0E.jpg]
[Image: 932727AD-968E-4FB6-8C2B-3D889A8FC563.jpg]
 Then off came the bonnet, gave the bay a clean, and chucked on my mates smooth bonnet. Not the best of condition but looks better than the lacquer peel
[Image: 74B3D3E7-75A7-4A6B-8C1F-AC1D673426FC.jpg]
Smooth bonnet means one thing right, smooth grill. I had to make this up, used fibreglass behind and filler on the front, it's not perfect as I had a bad paint reaction that was hard to correct, so will do for now till I can get working on it outside.
[Image: F8A93DB3-EDA2-4A72-A417-F43E73A442D4.jpg]
[Image: F353A7E5-724F-41F7-8477-BCF00BC7944F.jpg]
[Image: BC73A188-327E-489D-94F1-F8D826630822.jpg]
[Image: B7087C8E-DDEF-46E0-A818-40C3DE02E495.jpg]
[Image: 69A7A48B-0D4F-482D-8DC7-1CF6B498841E.jpg]
Archs were sorted also, it came with the archs "rolled" but they still scrubbed everything! So with no access to a arch roller I tackled it myself in the most bodgetastic way which I fully expected to fail, jacking the car up and putting carologues between the wheel and arch.......
[Image: A1C83BF3-682C-4010-98CD-8880C4684C30.jpg]
Fully expected to fail, but turned to work better than ever, arch is now clear of the tyre and in a relitively smooth flares
And next was to get it boosting, installed a boost gauge from an old project, used the pod I had, drilled into the a pillar and mounted. All wired in to light up with lights, but being so bright I stole a friends idea and tinted the lens yellow to make it more bareable
[Image: 53FF3F39-7A2D-4CBD-9BE0-4C05B9D33558.jpg]
Also in a moment of madness I painted the top of the rear lights, not sure if I like it yet.
Also dewipered the rear, as I hate wipers aha
[Image: 8E33C8FD-4651-483E-B0A1-9ED55E8EA00B.jpg]
Always nice to see another wagon project
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Looks good but needs the roof rails removing.
nice, another estate being recommissioned.
I may of missed it but what happened to the Rallye?
(17-01-2017, 04:27 PM)dr_jekyll Wrote: Always nice to see another wagon project
Wasn't meant to be a project, was meant to break it but fell in love with it
(17-01-2017, 04:38 PM)Dum-Dum Wrote: Looks good but needs the roof rails removing.
That is on the to do list, just can't be arsed dropping the lining
(17-01-2017, 04:46 PM)mr_fish Wrote: nice, another estate being recommissioned.
Will be used while I save for something else as it's so cheap.
Rallye is still with me, it's currently being returned to standard rust treated and under sealed
Bars bolt externally fella. Not hidden in the lining at all. I ran 35mm countersunk washers after removing mine for a while to hide the holes
Justin_306DTurbo
Luuuurv the wheels
Also an advocate of painting tops of rear lighrts.
.should have been that way from factory imo
(17-01-2017, 05:12 PM)dr_jekyll Wrote: Bars bolt externally fella. Not hidden in the lining at all. I ran 35mm countersunk washers after removing mine for a while to hide the holes
For real? Got a picture of yours?
You don't need to buddy, there is plastic caps on the rails, you pop them off and get to the torx bolts.
When I removed mine I put in the appropriate size grub screws in the holes with some silicone on the threads to seal them.
There is still a little dip then but it's much less noticeable.
3 plastic caps. One on each leg. Pull off and theres a big torx underneath threaded into the roof.
Best pic ive got fella. Can kinda make them out [Image: e00bcf11f4895c91b5b0be9bb5afba8c.jpg]
Which that pics actually really shit [FACE WITH TEARS OF JOY]
Justin_306DTurbo
I'd upload you a pic of mine but the forum uploader isn't working.
Justin what did you use to fill it? Counter sunk hobbies? Got a link? Yours looks class. Will whip them
Off tomorrow Smile
(17-01-2017, 06:17 PM)Matt Wrote: Justin what did you use to fill it? Counter sunk hobbies? Got a link? Yours looks class. Will whip them
Off tomorrow Smile
Cheers but its matte now [FACE WITH TEARS OF JOY]
[Image: 8cc22469ae11ba181ff6e78901fdca04.jpg]351357511927
Justin_306DTurbo
Sweet cheers mate, I'll whip them off tomorrow and see what I think
Seen this on Facebook and insta. Looks great with the lows and those wheels.
Yeah I've had it for about 3 weeks now, bloody love it.
Cheers mate, I love the wheels
I've gone barless! For now I just have the holes in the roof till I can get holes of some counter sunk bolts to go in.
Personally think it's looks great
[Image: D3A903B6-BA44-4EE8-A09F-75C6F477131E.jpg]
[Image: E973AFF2-251E-4E7F-ADF1-F4F4A3C1BF95.jpg]
[Image: C0944789-D2D7-43AA-BDF7-E003E8FB18A9.jpg]
Next is to try and sort the kerbing on the wheels
And sort some kind of routing for fmic
Those XXR doesn't look that bad on a 306 actually, very nice They don't need any spacing right ?. Looking foward to this project mate. Have Fun and good luck !
I'll have the roof bars if they're going! #vulture
Looks lush with no bars lad!
Justin_306DTurbo
(18-01-2017, 09:42 PM)Pingaz Wrote: Those XXR doesn't look that bad on a 306 actually, very nice They don't need any spacing right ?. Looking foward to this project mate. Have Fun and good luck !
No spacing on mine as far as I know. I think they look great! Cheers, gunna be a fun project
(19-01-2017, 07:07 AM)Poodle Wrote: I'll have the roof bars if they're going! #vulture
I'm keeping them incase I sell the car, but if I part it out you have first dibs
(19-01-2017, 11:23 AM)dr_jekyll Wrote: Looks lush with no bars lad!
Cheers mate, will look better with some flush bolts!
After seeing this the other day, well impressed with it. A tidy and quite smart looking motor!
  Matts cheap cherry rallye Matt-Rallye 15 13,843 02-01-2018, 08:45 AM
Last Post: Matt-Rallye
  Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. Matt-Rallye 29 24,742 10-05-2017, 12:49 PM
Last Post: Poodle
  Matts cossack S16.. Engine out, interior in! Matt-Rallye 86 51,170 18-09-2016, 08:03 PM
Last Post: Dum-Dum
