Key Barrel
Key Barrel
I've noticed on the 306 models on the barrel there either 2 or 3 wiring connectors meaning 6 pin or 4 pin with 2 in each.
My 306 hdi only has 2 connectors so 4 pins and 4 wires.
So whats the situation with this do I need the matching one or will there be a spare connector not used?
Pictures and links below Thanks
This mine 2 connector in my own car.
[Image: 20170109_150006.jpg]
These 3 connector type 1993 to 2002
http://www.ebay.co.uk/itm/Peugeot-405-Pe...Swu1VW4WPh
There is also a 2 connector type but says older models 1993 to 1997.
http://www.ebay.co.uk/itm/Ignition-Start...XQNo5TZOF8
you'll just have a spare connector from memory, earlier cars had a different immobiliser system.
(09-01-2017, 03:37 PM)welshpug Wrote: you'll just have a spare connector from memory, earlier cars had a different immobiliser system.
Strange that as mine is a 2000 model hdi with only 2.
I've added some pictures and links now.
never trust ebay listings lol.
if you have the option of a direct fit type then that will eliminate any chance of issues.
(09-01-2017, 04:45 PM)welshpug Wrote: never trust ebay listings lol.
I've just been to the scrap yard today. I can confirm that 2 306 diesel models there was a V reg hdi 1999 it had the 2 connectors and 4 pins. Then I seen the older diesel xud R reg 1997 with 3 connectors and 6 pins.
So I will go for the 2 connectors with 4 pins matching mine now.
The ebay listing for years is wrong for sure.
  306 Ignition Barrel stuck! 306clot 3 2,662 09-08-2014, 03:20 PM
Last Post: 306clot
  How do I remove ignition barrel?? Coops69 3 2,322 09-08-2013, 03:04 PM
Last Post: Scott
Sad Dodgy ignition barrel gratts 14 6,618 22-07-2013, 03:19 PM
Last Post: gratts
