What psi do stadard turbo go to
306 hdi
Stage 2
Its boosting at 18psi
Been told it turned up
If i get a boost controller
What would i turn it up to and still be safe ??
I used to run 21 psi on my ko3 hdi, stage 2 map and intercooler with a straight through. You will reduce the life of the turbo though, I'd recommend fitting something bigger such as a Gt2052 or an IHI rhf5. Alternatively, you can go down the vnt route and fit something like a Gt2056v There's loads of information in various project threads and the guides section if you want to read up on it.
(06-11-2016, 11:48 AM)Jonny81191 Wrote: I used to run 21 psi on my ko3 hdi, stage 2 map and intercooler with a straight through. You will reduce the life of the turbo though, I'd recommend fitting something bigger such as a Gt2052 or an IHI rhf5. Alternatively, you can go down the vnt route and fit something like a Gt2056v  There's loads of information in various project threads and the guides section if you want to read up on it.
After a straight fit one what good strong
There are no straight fit ones unfortunately! Need to get the welder out to fit any other bigger turbos
Id just keep it stage 2 until the turbo blows thenget a gt2052 or similar and go stage 3 then
That will be the best idear ha
Echo pretty much what MY95 said, but i would try and get your turbo up to about 20 psi on the stage 2.
(06-11-2016, 05:25 PM)Frosty Wrote: Echo pretty much what MY95 said, but i would try and get your turbo up to about 20 psi on the stage 2.
With boost controller ??
Yeah, think they are a bit fiddly to fit on a hdi with a standard turbo, to get the pipes onto the turbo and actuator. For it to be running 18psi someone must of adjusted the wastegate arm as i don't think it would see that much of an increase in boost with just upping the fuel on the map.
Yeah lad said turned up turbo like
