What psi do stadard turbo go to - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: What psi do stadard turbo go to (/showthread.php?tid=35144) |
What psi do stadard turbo go to - L16rye - 06-11-2016 306 hdi Stage 2 Its boosting at 18psi Been told it turned up If i get a boost controller What would i turn it up to and still be safe ?? RE: What psi do stadard turbo go to - Jonny81191 - 06-11-2016 I used to run 21 psi on my ko3 hdi, stage 2 map and intercooler with a straight through. You will reduce the life of the turbo though, I'd recommend fitting something bigger such as a Gt2052 or an IHI rhf5. Alternatively, you can go down the vnt route and fit something like a Gt2056v There's loads of information in various project threads and the guides section if you want to read up on it. RE: What psi do stadard turbo go to - L16rye - 06-11-2016 (06-11-2016, 11:48 AM)Jonny81191 Wrote: I used to run 21 psi on my ko3 hdi, stage 2 map and intercooler with a straight through. You will reduce the life of the turbo though, I'd recommend fitting something bigger such as a Gt2052 or an IHI rhf5. Alternatively, you can go down the vnt route and fit something like a Gt2056v There's loads of information in various project threads and the guides section if you want to read up on it. After a straight fit one what good strong RE: What psi do stadard turbo go to - MY95 - 06-11-2016 (06-11-2016, 12:31 PM)L16rye Wrote:(06-11-2016, 11:48 AM)Jonny81191 Wrote: I used to run 21 psi on my ko3 hdi, stage 2 map and intercooler with a straight through. You will reduce the life of the turbo though, I'd recommend fitting something bigger such as a Gt2052 or an IHI rhf5. Alternatively, you can go down the vnt route and fit something like a Gt2056v There's loads of information in various project threads and the guides section if you want to read up on it. There are no straight fit ones unfortunately! Need to get the welder out to fit any other bigger turbos Id just keep it stage 2 until the turbo blows thenget a gt2052 or similar and go stage 3 then RE: What psi do stadard turbo go to - L16rye - 06-11-2016 (06-11-2016, 12:49 PM)MY95 Wrote:(06-11-2016, 12:31 PM)L16rye Wrote:(06-11-2016, 11:48 AM)Jonny81191 Wrote: I used to run 21 psi on my ko3 hdi, stage 2 map and intercooler with a straight through. You will reduce the life of the turbo though, I'd recommend fitting something bigger such as a Gt2052 or an IHI rhf5. Alternatively, you can go down the vnt route and fit something like a Gt2056v There's loads of information in various project threads and the guides section if you want to read up on it. That will be the best idear ha RE: What psi do stadard turbo go to - Frosty - 06-11-2016 Echo pretty much what MY95 said, but i would try and get your turbo up to about 20 psi on the stage 2. RE: What psi do stadard turbo go to - L16rye - 06-11-2016 (06-11-2016, 05:25 PM)Frosty Wrote: Echo pretty much what MY95 said, but i would try and get your turbo up to about 20 psi on the stage 2.With boost controller ?? RE: What psi do stadard turbo go to - Frosty - 06-11-2016 (06-11-2016, 06:39 PM)L16rye Wrote:(06-11-2016, 05:25 PM)Frosty Wrote: Echo pretty much what MY95 said, but i would try and get your turbo up to about 20 psi on the stage 2.With boost controller ?? Yeah, think they are a bit fiddly to fit on a hdi with a standard turbo, to get the pipes onto the turbo and actuator. For it to be running 18psi someone must of adjusted the wastegate arm as i don't think it would see that much of an increase in boost with just upping the fuel on the map. RE: What psi do stadard turbo go to - L16rye - 06-11-2016 (06-11-2016, 07:28 PM)Frosty Wrote:Yeah lad said turned up turbo like(06-11-2016, 06:39 PM)L16rye Wrote:(06-11-2016, 05:25 PM)Frosty Wrote: Echo pretty much what MY95 said, but i would try and get your turbo up to about 20 psi on the stage 2.With boost controller ?? |
