Stef's beam builds
Stef's beam builds
#61
Are you able to offer a rebuilt beam without taking an old one in part exchange for a higher price?
62k Diablo Phase 1 Gti-6:
Project Thread
Yes I dont see why not.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
i'd be interested in a beam for my hdi (abs), but it'd have to wait til next year.
ideally, i'd like the refurb unit sent b4 returning the OE one, so that I can take it to KrisB for fitting.
is that a reasonable ask?
Hate Housework!
i dont stock many axles so we will have to work something out near the time.
05' Evo 9 IX GT
Team eaton.
(24-10-2015, 10:38 AM)Stef205 Wrote: i dont stock many axles so we will have to work something out near the time.
happy with that Smile
Hate Housework!
(24-10-2015, 09:42 AM)Stef205 Wrote: Yes I dont see why not.
Great. I might be in touch over the winter.
Project Thread
Quick bump
Still doing these Smile
05' Evo 9 IX GT
Team eaton.
fab, i'll be in touch in a month or two
Hate Housework!
I can recommend stef for work he did on my beam
replacing T bars and height adjustment Wink
GTI6 Info
Few messages lately about beams, Yes i am still doing them currently on a break as ive taken on a huge welding job which is taking all of my free time and wouldnt be fair to others to take on beam work. Will update when im all good again Smile
Stef Smile
05' Evo 9 IX GT
Team eaton.
No worries Stef. Let me know when you are back on with them and I'll buy one. I also need a 205 GTI subframe if you've hot any?
Sorry mate I'll reply to your message now
05' Evo 9 IX GT
Team eaton.
Forgot to update this.
I am now back to normal and beam builds are flowing again. My rebuilds still use oem parts and include new bolts and now all parts are shot blasted as standard! Price still remains at £280 for you guys.
Stef Smile
05' Evo 9 IX GT
Team eaton.
Had to swap a leaking shock on my beam today, was a pleasure stripping it off with the new bolts you put in, thank good you used a 22mm not 21 lol
(29-08-2016, 11:26 PM)rocker8742 Wrote: Had to swap a leaking shock on my beam today, was a pleasure stripping it off with the new bolts you put in, thank good you used a 22mm not 21 lol
Ha! the amount of people that praise the new bolts. In my eyes its a good finishing touch.
05' Evo 9 IX GT
Team eaton.
I think it's worth while with any replacement part tbh mate, makes life so much easier if you ever come back to it.
will have a gti6 axle available soon, Normal spec and build. Will be set to oem height unless sold before its built then will set to buyers requirements.
All oem parts and new bolts as standard. £280 on exchange, Exchange units MUST be in a serviceable condition.
Stef Smile
05' Evo 9 IX GT
Team eaton.
think my original beam may be seized.
Hate Housework!
Seized 306 beams are getting as common as the 205/309 stuff now. Ripe for the bin tbh
05' Evo 9 IX GT
Team eaton.
darn.!
what's the best way to determine?
Hate Housework!
Bounce the car see if it moves.
05' Evo 9 IX GT
Team eaton.
it's off the car, swapped with a used one I had.
Hate Housework!
pull it apart.
I had a 205 beam which was meant to have been built by a well known beam builder.
one side was seized, thankfully it came apart and we could use the arms, all 4 bearings had been installed back to front and too deep, seal clearances way too tight, and deep wear grooves under the outer bearings!!
next spring then - - - - maybe
Hate Housework!
available soon
Xsara vts axle
Good upgrade over the standard gti6 beam.
£300 on exchange of another vts axle
£350 on exchange with a gti spec axle
£380 straight buy out!
Stef Smile
05' Evo 9 IX GT
Team eaton.
Hi all,
I can now supply bigger dia bars. Prices below.
All Torsion Bars below 25mm
£280.00 per set
All Anti Roll Bars below 25mm
£145.00 each
Torsion Bars above 25mm
£300.00 per set
Anti Roll Bars above 25mm
£175.00 each
Hybrid Anti Roll Bars (306)
£185.00 each
Prices are plus post.
Stef Smile
05' Evo 9 IX GT
Team eaton.
Stef. just briefly, when sending a beam for refurb, do you need the support arms sent with it, or just the beam tube & trailing arms?
Hate Housework!
i dont need the support arms, but due to how they are bolted in standard form you can not remove them unless the beam is standard height you might get them off.
05' Evo 9 IX GT
Team eaton.
thanks. the beam will be off the car for that then.
Hate Housework!
