Rear Brake Compensators - why do GTI6 have it but not any other 306s?
As above, so why do GTI6's have a rear bias valve/compensator yet other 306s dont?
Anything with discs has it before EBD, not just GTi6s. All the ph3s should have the newer ABS with EBD so no need for manual compensator.
As above.
Some gti's do,some dont. As with the others. In fact...drum brake beams have them too iirc
Only ph3 gti6 dont
abs drum has one too
non abs drum has a pressure limiter in the rear cylinders
(08-10-2016, 01:46 PM)welshpug Wrote: abs drum has one too
Ah, I thought all drums had that, my bad.
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 12,958 18-04-2019, 10:14 AM
Last Post: Mighty306
  Uneven brake drag on rear wheels balkan_bozo 2 3,890 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Rear brake compensator leaking Ben 4 5,815 24-04-2018, 07:11 PM
Last Post: Ben
