That darn knock...VIDEO
Its the exhaust.
See project thread for exhaust mega fail
could you put a link to project thread please
#33
Yeah sorry ...
http://306oc.co.uk/forum/showthread.php?tid=8415
drive shaft intermediate bearing collapsed?
oh wait fail on my part explanation to this in another thread. Doh!
GTI6 Info
#35
seen the exhaust crack, maybe the culprit as engine "jerky"?? hope it is as that will be relatively inexpensive to fix. Under impression car was not such a "special". wow that tyre, you have been having fun!!
#36
(07-06-2016, 07:24 PM)pug306driver Wrote: seen the exhaust crack, maybe the culprit as engine "jerky"??  hope it is as that will be relatively inexpensive to fix.  Under impression car was not such a "special".  wow that tyre, you have been having fun!!
She is special alright...
eSpecially annoying at times!!
Hmmm. Think just too much heat/too little support
Looks like it started from the HAZ on the ropey weld nearby.
#38
Right...ropey crack fixed with more ropey weld. Need a real welder...and some skill...
Nevertheless... Still got a seperate suspension clonk n crunk...
Proper bugging me
new video so we can see/hear?
#40
(14-06-2016, 09:15 AM)pug306driver Wrote: new video so we can see/hear?
I may try to
Can here it on my track footage going through chicanes
Ok...so this got real bad after Pugfest. Seemed fine on route.
All makes sense as now found. Me and ruan wouldnt give up once I could jack it up in a certain position to make it knock by giving ghe wheel a.jerk in a certain way.
Turns out dry front nearside wishbone bush bolt essentially. Managed to get a 1/4 turn on it...but was SO creaky.
Wound out, cleaned up and greased up...wound in tight.
Now no creaks, crunches or clunks!! woopwoop
Got a photo showing the suspect bolts? Perhaps all of our 306s could do with tlc to those bolts? Presume not touched since factory?
#44
(10-08-2016, 10:24 PM)tigerstyle Wrote: Got a photo showing the suspect bolts? Perhaps all of our 306s could do with tlc to those bolts? Presume not touched since factory?
Ive edited my post... I was very tired... Its the front wishbone bolt. Long one with 18mm head
Interesting. So what - you just tightened it up essentially? (once you could that is) As said above, is this something we should al look at? Trying to understand what has happened here.
#46
(11-08-2016, 11:15 AM)carlukepeugeot Wrote: Interesting. So what - you just tightened it up essentially? (once you could that is) As said above, is this something we should al look at?  Trying to understand what has happened here.
Yeah essentially.
Managed 1/4turn or so.
Wound it out and it creaked all the way. Cleaned and greased and all is loverly jubberly
Maybe the captive nut inside the sub frame has come away from its weld as well?
(11-08-2016, 12:26 PM)Connor Wrote: Maybe the captive nut inside the sub frame has come away from its weld as well?
His is a phase 3 so the subframe nuts are not spot welded theyre just captive. Meaning they can rattle if a little loose. Bad design choice for the newer ones.
  GTi6 Knock Toms306 12 8,204 21-04-2018, 09:05 AM
Last Post: Toms306
  Rattly knock!! insomaniac45 4 3,113 22-07-2016, 01:18 PM
Last Post: Dale
  Knock Knock..... nick000 12 8,326 01-05-2014, 11:52 AM
Last Post: nick000
