27-05-2016, 08:45 AM
Got another week before I'm in work so might rebuild it
205 DTI
27-05-2016, 11:40 AM
28-05-2016, 04:20 PM
Got the Rev counter working
![]() Only Boosting 25ish psi, might have put the mbc on the wrong way Need to turn the fuel down its a bit smokey
28-05-2016, 05:30 PM
Need to increase the boost...
Never turn fuel down ![]() Wishes for more power...
28-05-2016, 05:32 PM
Wastegate issues...
Or the mbc I don't want to turn the fuel down but it's nearly undriveable because the boost isn't there Can find any boost leaks but I bet it's the elbow off the turbo which is the most difficult to get to
28-05-2016, 06:12 PM
....fits laggy td04...
Complains about coal and lagg ![]() Wishes for more power...
28-05-2016, 06:14 PM
I honestly think it's a bit of getting used to after driving my hdi!
By the way I'll have that head back to you soon, planning on doing the head gasket on the hdi tomorrow
29-05-2016, 04:04 PM
Now Boosting 2 bar + ish
29-05-2016, 06:38 PM
Wicked. I had can see this thing shifting.
TD04 is a good turbo for these engines IMO. Yeah there are faster spooling turbos but the TD04 gives a lot of top end push and I really liked mine. So much so I am getting another one for my zx estate. ![]() I Don't Have A 306.
29-05-2016, 07:06 PM
depends which td04, theres loads of different types
29-05-2016, 08:09 PM
(29-05-2016, 07:06 PM)welshpug Wrote: depends which td04, theres loads of different types Yawn. You say that every time somebody mentions a TD04. ![]() I Don't Have A 306.
because its fecking true
![]() got an 11 on my engine, im pretty sure that is very different to the 15 on my friends Saab.
29-05-2016, 08:36 PM
![]() Got that working finally! Took a while to work out. First time I've really loved at Rev counters ![]() The positive wire slipped out the plug by accident and touched the earth for a little while causing that. I swapped all the dials over into a stdt clock housing, everything works again. ![]() Found 5 dead bulbs ![]() May of hit 45psi earlier, it went waaaaay above 30 psi earlier
29-05-2016, 09:35 PM
Just got to find a way of positioning the boost gauge without bastardising the plastic interior
30-05-2016, 08:43 AM
01-06-2016, 02:29 PM
01-06-2016, 02:34 PM
They do fit on the battery tray just fine - although the other style of pump with the integrated reservoir is better if you're going to install it that way (IMO)
Definitely no way that it'll fit underneath the expansion tank? Normally they squeeze in down there, but not sure it will with the boost pipework on yours.
01-06-2016, 02:55 PM
Boost pipe bang in the way so no chance of that
04-06-2016, 10:00 PM
29-01-2017, 05:16 PM
29-01-2017, 05:23 PM
Good to see this is still going Paul! Don't let that bloody bimmer take up all your time.
03-02-2017, 09:47 PM
