27-04-2016, 01:54 PM
help needed! Want to remove the air bag in the dash my my ph2 gti6. Iv got the glove box and I know it's a straight swap but what do I need to do about the air bag light? Cheers
Air bag removal
27-04-2016, 02:04 PM
Cully on here does the resistor kits to turn the light off
27-04-2016, 02:10 PM
Can't you just turn the airbag off with the key down by the headlight adjuster?
27-04-2016, 03:37 PM
(27-04-2016, 02:10 PM)Mattcheese31 Wrote: Can't you just turn the airbag off with the key down by the headlight adjuster? yes but it brings up another light saying it is disabled ![]() I do sell fused resistors if you are interested PM me https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
27-04-2016, 03:44 PM
yeh you need fused resistors. And... you can fit a top glove box but you will be missing the metal frame so it will be slightly insecure and a few screws wont grip.
27-04-2016, 03:58 PM
(27-04-2016, 03:44 PM)Eeyore Wrote: yeh you need fused resistors. And... you can fit a top glove box but you will be missing the metal frame so it will be slightly insecure and a few screws wont grip. there is no metal frame that I recall, you just use those little metal clips that slot on the holes then the screws go through them, don't know what they're called
(27-04-2016, 03:37 PM)cully Wrote:(27-04-2016, 02:10 PM)Mattcheese31 Wrote: Can't you just turn the airbag off with the key down by the headlight adjuster? Hi mate I can open your pm but it won't let me reply for some reason my account is verified so tech glitch I presume
27-04-2016, 04:03 PM
add me on FB addy is in my profile here
![]() am at work ATM maybe slow replying https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly. |
