Project faith. 2.1 8v HAS TO GO :(
(05-04-2016, 12:13 PM)Iaitoo Wrote: Are the bonnet struts your own making, or did the newer 306's come with em?
Bonnet struts are standard on Phase 2 and 3 thats for sure. Not sure what phase 1 have.
Ah, cool. Mine has a stick Tongue
Phase 1 has a stick (or stand). Ph2 and 3 have the struts.
I drove this car on the road tonight......
:O :O !
Yaaaay!
Why only 5psi though?!
Yeah as piggy says. Only boosting 5 psi. Suspect actuator needs some re aligning or something. Drives fine apart from that. Ive got a list of little jobs that still need doing as well. Then after she is perfect i can start tidying her up for fcs.
yesssss quality! Big Grin
Nice one! Big Grin
Good man, well played, good speed too Smile
(05-04-2016, 10:54 PM)bashbarnard Wrote: I drove this car on the road tonight......
AWESOME!
We have 25ish psi now. No idea what these turbos are "safe" to bit thatll do for now
What did you have to do to get the extra boost?
Good progress though, you have cracked on with it fair
(06-04-2016, 12:58 PM)Frosty Wrote: What did you have to do to get the extra boost?
Actuator wasnt in the correct place. Cut and shortened rod on linch break. Will use mbc to fine tune it
So now this has been on the road a few days i feel like i can actually update on this "engine feel" amoung other things. To start with this feels just like a 2.1 toqueful and lazy revving a but puts on speed and a substantial rate and doesnt feel hurried or laboured at all. The rhf5 turbo is defiantly a different feel to the gt20 i use to run. The torque curve is a LOT smoother. Takes a little longer to come on boost but when its on boy its there and begging for more fuel than ive dialled in but leaving it as is till ive got time to tune it correctly.
Now the bad bits ive found, p bushs need doing which i have. o/s driveshaft seal needs doing as its leaking. got that as well. exhaust knocks but i have a 2.5 inch system to build and put on. n/s/r calliper has a slight leak so needs replacing.
Now the REALLY f*cking BAD BIT. i bought the car covered in dirt. for £40 for parts for another car then proceeded to find £6 in it so its a £34 car with mot on. however a little bit on the rear quarter needs painting that i missed. some bastard has ratlle canned it. pikey arse. Those people that have been to my workshop know that my mate has a fully functional spray booth to hand! and as the bumper boot and grill needs a little touch up i may just go full hog and change the colour.
Thought opinions and general banter is welcomed as normal. really want so input guys. at the end of the day this car has been built from the stuff i read and hear about on here.
(06-04-2016, 12:46 PM)bashbarnard Wrote: We have 25ish psi now. No idea what these turbos are "safe" to bit thatll do for now
for now... sure
joking aside, sounds good. really put some progress on with this already.
you had a good go at describing the motor feel, but really much different from the 12v head?
I don't really have an opinion on paint I'm afraid, it is such a can of worms!
for now... sure
I think that the longer stroke has more of a impact on driving feel than the head to be honest. now ive had both. obvioulsy this isnt an entirety fair comparison due to different turbos. however if i was to build another one it would be 8v head as its just easier to get parts if things go wrong and better clearance.
The paint thing is up for debate. ive wanted a black car but i hear its a bitch to spray
rattle can matt black? panel at a time, you'll be fine.
(08-04-2016, 07:36 PM)zx_volcane Wrote: rattle can matt black? panel at a time, you'll be fine.
my workshop has a full spray booth and equipment in. im not rattle canning it i want a front row seat at fcs this year.  Itwasntme
Paint it yellow to match the wheels [emoji106]
Kawasaki green or ST orange... Big Grin
Good to hear she is boosting well.
Time for more fuels n boosts
If you paint this some rediculous colour or make it any more lairy I will disown you.
(08-04-2016, 11:18 PM)Eeyore Wrote: If you paint this some rediculous colour or make it any more lairy I will disown you.
Yeah im going to paint it bright pink and run those yellow wheels you gave me
That would actually be kinda cool. But maybe a bit too JDM for a french car Tongue
If you don't paint it in glow in the dark paint I'll be disappointed.
Truned down the boost today. It was a decision that had to be. I was running 28psi and couldnt fuel it enough. Got it down to 25/26 and it goes the same. Really needs a 10mm pump on it.
Also got the rad fans wired in so when i swith on "front fogs" it comes on. Check strap done. Antifreeze change. And drilled some holes in the grill may even give her a first wah tomorrow.
Oh man thats a great idea... I bet the rallye fog wiring is still in the loom. Maybe i could turn my fans on and off with that if i fitted a fog stalk.
Aubergine purple.
Fog lights for fan operation lmao
