Stage 3 head lift?
Stage 3 head lift?
(22-01-2016, 06:06 PM)HDi--Power Wrote: Arp's really wont be necessary, I don't think anyone has had head lift or gasket failure from running 200hp plus, the issues all stemmed from elsewhere.
I know you have fair bit of experience...
But I wouldn't say I totally agree there... A LOT more air flow at mid range RPMs is going to lift the head on stock bolts.
Seen lift with less power
Yea but the hdi's don't seem to suffer from it, the 180 hp standard Peugeot models now even still use the same bolts as in our dw10. I don't recall ever hearing of one lift the head, even the 230+hp Danish varieties. Realistically 26 ish psi on a decent turbo will be enough for over 200hp on these and keep everything happy.
Totally depends on the tuning, excessive torque can cause it... It should be tuned around, just like EMP.
GT2052S is good for 180 BHP with 24-25 psi of boost on the 2.0 HDI 8V.
Any more than that and you'll have back pressure problems and the lifters will start collapsing or you'll snap a rocker.
I ran a GT2052V (VNT) on my 1.6 HDI at 26-27 PSI and that gave me 210 BHP, but these are 16V and can rev unlike the 2.0 8V.
My advice would be to stick at 180 BHP (tested on a real dyno with realistic figures) and save yourself the trouble. I've set up a few with these turbos already.
Edit: But to the original question don't worry about head lift, this seems to affect the VW boys but never seen it on the HDI yet.
HDI Tuning Ltd
www.hdi-tuning.co.uk
