Threads: 476
81
Car Model/Spec: 306 Rallye
Hi All,
Fitting the new beam to my rallye and the brake lines on the beam need replacing. Ive found that 4885 34 and 4885 33 are possibly the part numbers from peugeot but dont know that these are right. Would be great if they still make them preshaped etc. The rallye has the bias valve on it. Ive checked service box but there seem to be lots of options for rear brake setups. Can anyone have a look for me and confirm what numbers they are?
Thankyou!
Threads: 581
195
Bang your VIN in and it will give you the exact right ones.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
No longer available from pug
Threads: 476
81
cheers tom. ive heard that from enough people now that i wont bother asking my local. looks like ill be getting some copper nickel pipe and then i need the fittings which i believe are M10x1.00.
I believe that this kit is all I need! Can someone sense check for me?
http://www.ebay.co.uk/itm/Copper-Nickel-...H78ps9a0bw
tom has a flaring tool and i believe the nickel copper lines are harder than copper so i dont need a special tool to bend them?
Threads: 58
5
Car Model/Spec: 205 gti6 supercharged
any will be fine in m10x1 and for 3/16 pipe
Threads: 476
81
okay ordered now! looks like we should be good. delivery is 31st to 6th which is annoying but oh well. plenty to be getting on with
Threads: 581
195
If you let me know when you're doing these lines with plenty of notice, ill try and borrow the MICC kit from work so we can get the copper perfectly straight and bent where needed. Will look pukka
Threads: 386
87
That would be useful tbh... Likely to have spaghetti under there otherwise...like one of my previous HDi's...
Threads: 476
81
got 25ft of the stuff so plenty of chances to get it wrong!
Threads: 127
33
you can check on service box, they have nsf (iirc? or some other acronym) listed next to items that are no longer available.
if you're going into manufacturing, I'll take a set for rear please xx
Threads: 8
(28-12-2015, 07:14 PM)Eeyore Wrote: Hi All,
Thankyou!
Those part numbers are the right ones for left/right hand sides & are still available to buy pre-shaped from peugeot as i replaced mine earlier this year with them instead of having some made up/ faffing about shaping them & they even come with the plastic coating on .
Threads: 541
124
Wait which pipes is it you need as I had the hard pipes for the beam for my rallye earlier in the year from peugeot and yes they were perfect. It's only the short u shaped pipe that isn't pre shaped.
Threads: 127
33
29-12-2015, 08:27 AM
(This post was last modified: 29-12-2015, 08:33 AM by zx_volcane.)
(29-12-2015, 01:46 AM)Pgtips Wrote: Those part numbers are the right ones for left/right hand sides & are still available to buy pre-shaped from peugeot as i replaced mine earlier this year with them instead of having some made up/ faffing about shaping them & they even come with the plastic coating on .
(29-12-2015, 08:16 AM)Dum-Dum Wrote: Wait which pipes is it you need as I had the hard pipes for the beam for my rallye earlier in the year from peugeot and yes they were perfect. It's only the short u shaped pipe that isn't pre shaped.
Phoned two Peugeot dealers and they told me they couldn't get them anymore.
If you know a dealer that definitely has them please do let us know.
Knowing dealers you're probably right, had a complete farce trying to get gbox oil from one down in London, repeatedly told me it was no longer available!
Threads: 102
18
29-12-2015, 09:01 AM
(This post was last modified: 29-12-2015, 09:02 AM by RetroPug.)
Making up the lines is actually very easy if you're using copper as it is very easy to bend even by hand.
The hard part is getting all the ancient, crusty unions apart.
Threads: 386
87
Getting the unions undone was easy...they were seized to the pipes though so twisted them.  Though the long pipe ripped extremely easy so probably just as well we've gotta replace that as it may not have taken track abuse!
The ones we definitely need are the two short ones between the flexi lines and caliper. And the long one from the load comp to the flexi on the NS.
Threads: 465
114
Car Model/Spec: Vauxhall
building track car running the lines inside the car?
Threads: 476
81
(29-12-2015, 09:19 AM)cully Wrote: building track car running the lines inside the car?
mmmm its kind of track and kind of classic. Its pretty much going to be like the 1.8 so carpets in etc.
Threads: 8
(29-12-2015, 09:01 AM)RetroPug Wrote: Making up the lines is actually very easy if you're using copper as it is very easy to bend even by hand.
This is the reason mine needed replacing because of seized unions twisting the pipe when changing the perished flexible rear hoses but they're definatley still available from peugeot
Threads: 5
1
Car Model/Spec: 306 GTI-6
Not sure for the option in each model, I have seen many rear beam of 306 from the 2nd hand part shop.
some of them have 6 flexible hose, some of them only 4.
My Gti-6 also have 6 hoses but I already use the copper pipe instead flex hose t the Rr. beam. that work perfectly.
1999 306 GTI-6 PT81 & Remapping
2000 406 SRI 2.0 Turbo 6M/T @ 1 Bar Boosted
Threads: 476
81
ive got braided rears which i havent fitted in about two years. Finally theyll make it onto a car!
Threads: 102
18
(29-12-2015, 09:11 AM)Toms306 Wrote: Getting the unions undone was easy...they were seized to the pipes though so twisted them. Though the long pipe ripped extremely easy so probably just as well we've gotta replace that as it may not have taken track abuse!
That's what I did for most of them, just twisted them off or cut them off and then made up a new union to fresh copper pipe.
