Cold start 2.0hdi
Cold start 2.0hdi
Hi all when I got to my car in a morning if it's cold my heater plug light comes on but only stays on for a matter of seconds and my car struggles to start or don't start at all its my daily car I use it for work and it's let me down this morning  I've tested the battery and it's fine Wat could it be hope somebody can shed some light on it thanks xxx??
possible 'tired'/worn out glowplugs
Hate Housework!
It's nowhere near cold enough yet that it should be having any difficulties starting even without waiting for the glowplugs, assuming it's an HDi as per your profile.
When you say that it struggles to start, is the starter cranking over at normal speed or is it laboured/slow?
i have seen my glowplugs flash on once in the past year for about half a second (literally) when it was -8 outside. These should start easily without glowplugs in all but the coldest weather (i am talking negative figures here).
possible causes are:
tired or dead starter (will sound laboured when cranking and as if it's struggling)
knackered lift pump in the tank,
Possibly a temp sensor somewhere,
Blocked fuel filter
have a look at this (very detailed) post:
http://306oc.co.uk/forum/showthread.php?tid=1497
/Toseland
HDI uses glowplugs even if the light dont show get them tested
if the battery is weak the ecu will shut down due to lack of volts
GTI6 Info
Should still start though, even if it will run like a bag of shit
/Toseland
if the volts are low to the ecu it will never start but it will keep turning over!
GTI6 Info
Does it run on after switching off?
Glow plugs will not prevent it from starting this side of -10. When you say you've tested the battery, how did you do it, was it a proper drop test?
3 of the 4 glow plugs were not working so changed all 4 starts fine now thanks everyone ???
Interesting, i'll stfu lol, thanks for updating.
  Exhaust for berlingo 2.0hdi 205diesel 4 3,668 08-10-2018, 08:45 PM
Last Post: riw@mail.com
  Peugeot Partner 2.0HDI 90 | Intercooler | Boostontroller | Gauge 4Ward-Performance 6 6,592 24-03-2017, 09:16 AM
Last Post: pro_steve
  just picked up a hdi cold start problems maxlee 22 12,328 15-01-2014, 05:00 PM
Last Post: Poodle
