"Arie pronk" strut brace
#61
(19-12-2015, 08:33 PM)Toms306 Wrote:
(19-12-2015, 08:30 PM)dr_jekyll Wrote:
(19-12-2015, 08:27 PM)Toms306 Wrote: Maybe it's not a 205 one (first pic on google linked to 205 site!). Have now put a better pic up anyway. Smile
I'm not sure if they can be swapped over, the extra lump must be for extra capacity but I don't know why or if it is necessary.
Got a local scrapyard im sure i could find one in. Dont want to change it if its gonna cause problems.
Do you think it might hold the same volume but just be a diff shape?
I honestly couldn't say, I've only ever owned/worked on phase 2/3s and they've all had the res with the lump which is why it seemed odd to see a flat one. You would have to physically test the volume that each holds to see if there's any difference.
Obviously it can be swapped that'd be ideal!
Got a scrapyard local with several 306's so will go try source one monday and have a play while im there. Might be an easy solution to the problem.
Would mean having to close the paypal case but i do still want to use the brace if i can. Was absolutley guttered when i couldnt.
Thanks tom!
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
#62
No worries, good luck. Wink
  top strut brace bolts kernow_joe 13 9,238 27-09-2012, 06:24 PM
Last Post: swampy
