So, had a calliper binding on for ages now even though its been refurbed with seals and piston, and a new flexi and main brake pipe from calliper. Pads and discs fine and free of gunk/dust in usual places, wheel bearing fine too. Any ideas? I know that my brake servo possibly has a leak somewhere as the pedal goes hard at idle after a few pumps. Doesn't give off much heat with a heavy enough braking session but just doesn't spin much at all!
Refurbed calliper still binding
12-12-2015, 07:03 PM
Can only be the MC left after changing everything else!?
Take the pipe off at the caliper and Gert a mate to press the pedal, see what happens....
Plenty of fluid out and all appearing normal, its gonna be the caliper. Anything else, its gonna be mc
Thanks given by: MY95
12-12-2015, 07:34 PM
That's what I was thinking Tom! Hope not as they aren't cheap though.
Will try that, cheers Ben!
12-12-2015, 07:50 PM
check your stub axle to see if its bent slightly had this a few times
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
12-12-2015, 11:44 PM
Are the pads and sliders well greased? Often find that just giving everything a clean and regrease can fix the issue.
13-12-2015, 12:01 AM
Yes Poodle I always keep on top of the sliders and the pads are all good :
![]() Dont think its stub axle as one side is a bit worse than other and at first one side was binding on and the other was spinning very freely.
13-12-2015, 06:46 PM
So, don't think its MC as the rear brakes are spinning freely, so guessing that's MC out of the equation?
13-12-2015, 08:13 PM
Are the sliders all straight? Erm, struggling for many more ideas tbh, perhaps flush the fluid if it's old.
Sliders straight and all fine and fluid is only about a month old.
So defo not MC because of the above?
13-12-2015, 08:32 PM
Scrap the car and buy another one...
![]() On a serious note, is there any possibility that the ABS pump could have an internal fault that's restricting the flow through that?
13-12-2015, 09:30 PM
Have been tempted Tom
![]() Naa aha. No issues with anything ABS related Tom
It is possible yeah, although pretty unusual. Just trying to exhaust the other, much cheaper options first lol. There's usually a light accompanying the problem, but not always...
| rear brake binding | hedgeling106 | 12 | 7,572 |
10-12-2016, 11:20 PM Last Post: Piggy |
| Eibach/B4 coils binding? | wld | 11 | 9,291 |
16-10-2016, 04:49 PM Last Post: wld |
| Rolling road - split driveshaft boot and binding rear brakes reduce power on graph? | MY95 | 28 | 12,721 |
23-03-2016, 12:33 PM Last Post: tigerstyle |
