Estate fuel tank
Estate fuel tank
Hi peps I am having a problem with my fuel tank and need a new one.
S question is are the estate ad hatchback fuel tanks the same?
Got to love it when you have no ideaDodgy
You're in luck, there's one in my garage. I don't know if they're the same, but if they are you can have that for a tenner.
What's wrong with it?
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
(01-12-2015, 07:35 PM)C2K Wrote: What's wrong with it?
The screw part of the fuel sender is cross threaded causing it not to hold it down.
THere for leaking when full to half full when I turn left or break
So not good
(01-12-2015, 06:25 PM)Poodle Wrote: You're in luck, there's one in my garage. I don't know if they're the same, but if they are you can have that for a tenner.
Yeah kl just nneed to find out if the same lol
Sure it's not just a dodgy ring (oo err!), never heard of someone cross threading the tank myself, even I haven't managed it! lol
Seen it a couple of times. My silver one with the fuelling problem needed a new tank because the ring has been crossed on and the hole had ovalled with the pump swinging around.
Exactly as poodle said it's just swinging around so not sealing right
And check if it was ring but the one we got did the same even tho they were both fine
Fair enough then, seems odd they wouldn't make the ring the weakest point! I'll have to be more careful in future now haha.
On topic, the fuel tanks should be the same, I haven't noticed any differences between estate, 5 door or 3 door having broken all of them. Servicebox will confirm that though.
Fuel tanks are different depending on what pickups etc you have from what ive seen.
Ah that would make sense, I've only broken HDi's tbf.
Now i thought it was only the pick up that changed, will try and remember to check that out later. Or the op can just look on servicebox lol.
air vents off the top of the tank differ with age too
GTI6 Info
So as long as it's a hdi it should be the same tank no matter if it 3 door 5 door or estate
  In tank pump fuel strainer Welshy_Pete 2 2,776 20-05-2015, 09:32 PM
Last Post: Welshy_Pete
  Hdi estate - fuel leak mad306man 9 6,105 27-02-2013, 10:20 PM
Last Post: C2K
