1.6HDI ENGINE???
1.6HDI ENGINE???
Anybody clues up on the 1.6 Hdi engine?? I have a Berlingo which is turning over but not fireing up?? Anyone any ideas??
Hit any bad potholes today? Inertia switch! Find it and press it see if this helps, on the 306 there's a big brown relay behind the ecu that occasionally needs pulled and replaced before it will start after flat battery's etc! Don't know if these will help but got to be worth trying!
Any previous history to the problem? Codes?
Cam/Crank Synchronisation maybe.
Get PP2k on it... Or at the very least a generic OBD reader. You're just shitting in a fan otherwise.
The van was driving 100% then just cut out one day. It's been Layin at a mechanics as over a year now, he's tryed replacing the pump, brain, bci unit. He reckons now there's a broken wire in the engine loom somewhere. Anyway getting the van collected tomorrow. Gona get it plugged in and go from there. Also have the chance to buy another van which was hit. Thinking of buying it an getting whatever my van needs off it to get it going
As Tom said get in plugged in first and go from there. Out of interest is it the new type berlingo or one of the older shapes?
The last of the older shapes 2008 uses the new engine tho
Ah was thinking it was probably last of that type, I wouldnt mind one of the newer shape ones to fix up.
Sounds like you need a better mechanic tbh, get it to somebody with proper diagnostics otherwise you're just fumbling in the dark.
Shit mechanic is right i would say.
The it's showing up fuel pressure faults
Did it run out of fuel/change fuel filter? If so they need bleeding, no lift pumps.
Otherwise, fuel pressure is quite a wide area, could be a few sensors or pump even. Confused
Got it sorted it was two fuel pressure sensors, sat at a mechanics yard all that time and me and a mate had it goin in a hour lol
  Weird one, anyone got a 1.6Hdi crank pulley floating around? Rippthrough 0 1,733 02-12-2012, 02:50 PM
Last Post: Rippthrough
