oil cooler thoughts
oil cooler thoughts
thinking of getting an oil cooler kit in due course, any recommend/avoids?
want a simple, thermostatted 'bolt in' kit.
already have a sandwich plate fitted for gauges.
any decent suppliers?
Hate Housework!
How hard do you drive it? Anything short of track use really shouldn't cause a problem.
Get an oil temp gauge.
If theres no issues... No reason to fork out ThumbsUp
You might find a better oil would help enough anyway
P1 XSi track car
2.4 LWB T4
Ah! current oil is Comma 10w40 semi, temp & press gauges already fitted, was showing 110/120c on crawl past heathrow last Fri. (mind it could the sender earth)
Hate Housework!
Not being funny, but an oil cooler isn't going to help much in standing traffic. Would probably be better off with a coolant flush and refresh, although tbh in traffic there's not a whole lot you can do to help. Have you had any other problems with overheating? Do the engine fans and interior heater work well?
das ok poodle. I was thinking it may help get it cooled quicker once underway again.
afaik, everything is in good working order, fans keep water down to 75-80-ish, and inside gets nice and toasty/sauna.
think i'll check gauge connections again when I get a lump of time.
(temp gauge has only been in since the summer, so maybe I not used to it fully)
Hate Housework!
Sounds like a standard gti6 then.
^-^ Tongue
Hate Housework!
All sounds spot on tbf. Don't get me wrong, if you want to fit an oil cooler you go for it, just thought i'd stick my oar in with options. Big Grin
isn't that what this club/f0rum is for? Wink
(i'd prob add a small fan to it if there were 'traffic issues' )
Hate Housework!
