oil cooler thoughts - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: oil cooler thoughts (/showthread.php?tid=32157) |
oil cooler thoughts - Magenta Sunset - 08-10-2015 thinking of getting an oil cooler kit in due course, any recommend/avoids? want a simple, thermostatted 'bolt in' kit. already have a sandwich plate fitted for gauges. any decent suppliers? RE: oil cooler thoughts - Poodle - 08-10-2015 How hard do you drive it? Anything short of track use really shouldn't cause a problem. RE: oil cooler thoughts - Piggy - 08-10-2015 Get an oil temp gauge. If theres no issues... No reason to fork out ![]() RE: oil cooler thoughts - adam b - 08-10-2015 You might find a better oil would help enough anyway RE: oil cooler thoughts - Magenta Sunset - 09-10-2015 Ah! current oil is Comma 10w40 semi, temp & press gauges already fitted, was showing 110/120c on crawl past heathrow last Fri. (mind it could the sender earth) RE: oil cooler thoughts - Poodle - 09-10-2015 Not being funny, but an oil cooler isn't going to help much in standing traffic. Would probably be better off with a coolant flush and refresh, although tbh in traffic there's not a whole lot you can do to help. Have you had any other problems with overheating? Do the engine fans and interior heater work well? RE: oil cooler thoughts - Magenta Sunset - 09-10-2015 das ok poodle. I was thinking it may help get it cooled quicker once underway again. afaik, everything is in good working order, fans keep water down to 75-80-ish, and inside gets nice and toasty/sauna. think i'll check gauge connections again when I get a lump of time. (temp gauge has only been in since the summer, so maybe I not used to it fully) RE: oil cooler thoughts - Eeyore - 09-10-2015 Sounds like a standard gti6 then. RE: oil cooler thoughts - Magenta Sunset - 09-10-2015 ^-^ ![]() RE: oil cooler thoughts - Poodle - 09-10-2015 All sounds spot on tbf. Don't get me wrong, if you want to fit an oil cooler you go for it, just thought i'd stick my oar in with options. ![]() RE: oil cooler thoughts - Magenta Sunset - 09-10-2015 isn't that what this club/f0rum is for? ![]() (i'd prob add a small fan to it if there were 'traffic issues' ) |
