Threads: 101
Car Model/Spec: 306HDi 90 LX
thinking of getting an oil cooler kit in due course, any recommend/avoids?
want a simple, thermostatted 'bolt in' kit.
already have a sandwich plate fitted for gauges.
any decent suppliers?
It goes, it stops (as reqd).
Hate Housework!
How hard do you drive it? Anything short of track use really shouldn't cause a problem.
Threads: 15
Car Model/Spec: XSi
You might find a better oil would help enough anyway
P1 XSi track car
2.4 LWB T4
Threads: 101
09-10-2015, 06:20 AM
(This post was last modified: 09-10-2015, 06:21 AM by Magenta Sunset.)
Ah! current oil is Comma 10w40 semi, temp & press gauges already fitted, was showing 110/120c on crawl past heathrow last Fri. (mind it could the sender earth)
Hate Housework!
Not being funny, but an oil cooler isn't going to help much in standing traffic. Would probably be better off with a coolant flush and refresh, although tbh in traffic there's not a whole lot you can do to help. Have you had any other problems with overheating? Do the engine fans and interior heater work well?
Threads: 101
das ok poodle. I was thinking it may help get it cooled quicker once underway again.
afaik, everything is in good working order, fans keep water down to 75-80-ish, and inside gets nice and toasty/sauna.
think i'll check gauge connections again when I get a lump of time.
(temp gauge has only been in since the summer, so maybe I not used to it fully)
Hate Housework!
81
Sounds like a standard gti6 then.
