Threads: 448
51
So I have a leaking steering rack, a cv boot with a split and a bj with a little play.
Will these cause the car to fail a mot?
Just need to know wether they are going to be high priority on my fixit list or not
Threads: 371
29
Car Model/Spec: ford fiesta
Steering rack leak will only fail if it effects the steering or the oil is over a brake component. Cv boot is a fail regardless, ball joint depends little movement can be advised but you will find most testers will just fail them from my experience. Hope it helps. ?
As bash says tbh
Although iirc inner boots are advise only now.
But bj n cv boot wana be sorted asap tbh regardless
Threads: 110
20
All depends how bad it is and what the tester is like TBH
Threads: 448
51
Okay cool, haven't got the time to replace a steering rack before the test. Boot and bj are easy. I'll just chuck one of those repair boots on it. I can't even see the tear in the boot
Threads: 110
20
All cv boots fail if leaking bad enough
Threads: 448
51
Boots not leaking though. It's just got a tear, must have been very recent, as I've not seen it while working on the car haha
