Mot fails?
Mot fails?
So I have a leaking steering rack, a cv boot with a split and a bj with a little play.
Will these cause the car to fail a mot?
Just need to know wether they are going to be high priority on my fixit list or not
Steering rack leak will only fail if it effects the steering or the oil is over a brake component. Cv boot is a fail regardless, ball joint depends little movement can be advised but you will find most testers will just fail them from my experience. Hope it helps. ?
As bash says tbh
Although iirc inner boots are advise only now.
But bj n cv boot wana be sorted asap tbh regardless
All depends how bad it is and what the tester is like TBH
(23-09-2015, 05:58 AM)Piggy Wrote: Although iirc inner boots are advise only now.
Are you certain? I've been told a few times they used to be but are now a fail if split?
Tbh, no I'm not lol! Needs clearing up this...
However, as much as its a pig of a filthy job, any CV boot that is split wants doing asap. Makes such a mess and the £8 of a boot to save a £50 shaft makes eco sense
Okay cool, haven't got the time to replace a steering rack before the test. Boot and bj are easy. I'll just chuck one of those repair boots on it. I can't even see the tear in the boot
All cv boots fail if leaking bad enough
Boots not leaking though. It's just got a tear, must have been very recent, as I've not seen it while working on the car haha
