Back brake pads.
Back brake pads.
On the back brake pads on a 6, what are the wee wire things on the pads? What do they do? Do you need to put them back on when you change your pads?
All suggestions welcome as always!
Will
you mean the retaining spring? Yes that is needed do not fit without and take note of which way they go most are fitted incorrectly.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
They are not retaining springs, they are anti rattle springs, the little L shaped bar is the retainer.
Yeah the retainers in, I just wondered what the wire things were for, thanks for your replies! Smile
Will
They're anti rattle springs as above...let me know if you work out the magic behind how they actually stop rattling though! lol
Wires to the pad itself? prob pad wear circuit.
Hate Housework!
(12-09-2015, 11:21 AM)Toms306 Wrote: They're anti rattle springs as above...let me know if you work out the magic behind how they actually stop rattling though! lol
easy fit them properly...
(13-09-2015, 10:00 AM)Magenta Sunset Wrote: Wires to the pad itself? prob pad wear circuit.
not on the rear pads.
I fit them properly...they work... I just can't understand how!! Confused
I can't understand how you don't understand.
its a spring, holds the pads under tension, stops rattling.
But it's only on the pad, if it was also held onto something immoveable like the carrier I could understand it, but it's just on the thing that's moving in the first place!? Maybe I'm overcomplicating this somehow...
Or you're fitting them wrong lol. They should be under tension once the retainer is in too.
I just fit them how they come off lol, or use the other side or a spare 306 for reference. The springs themselves are under tension, but only on the pad. Confused
they should be against the carrier.
Only the top of the loop is against the carrier, is that really all it needs? I have been overcomplicating this then, my bad. Tongue
theres a pretty good picture in the Haynes manual....shows how they fit........modified split pin ( shortened ) to hold slider plates in works well.....big red do new slider plates also...
  Best brake fluid and pads? JTaylor2005 19 10,646 19-08-2016, 08:09 PM
Last Post: Pgtips
  Brake pads??? conorpierce 7 4,453 07-08-2015, 10:58 AM
Last Post: PartyJas
  306 rear brake pads. Pebbles167 4 3,173 06-07-2015, 03:59 AM
Last Post: maxzy
