Lucas to Bosch help
Lucas to Bosch help
Hi all. My shitty Lucas pump is finally giving up the ghost so I'm swapping it for a bosch. I'm having a mechanic do the work but he's never done the swap before. Is there a step by step guide on here somewhere or can anyone point out any issues he might have while doing the swap. All help is appreciated!
Ok u will need
The bosch pump with the pully and injectors with the lines to
It's a easy swap you can use the bosch pump bracket or just swap the studs in ur own over to the extra holes .
Make sure to take the cover off the pump that covers the solinod wen fitted take a wire from the solinod and find the ignition wire in the old lucus pump plug that should give you power to the pump
Also make sure you don't make my mistake and get a ecu controlled pump lol
If you need any more help or a pic or too just shout :-)
Some one will probably be a long soon to fill in any thing I might have missed but that the basics of it
.Good luck and hope all goes well   Itwasntme
This is the pump u will be needing
sorry to hijack but im doing the swap as well and the bit circled in the second picture does that need power what is it?
These two videos I made some time ago should help you out.
https://www.youtube.com/watch?v=NBfiyZzhIfM
https://www.youtube.com/watch?v=RfTnbjIJnCs
[Image: sigi-2.png]
  Substitution pump Lucas with Bosch AmedeoRS 3 3,908 13-05-2016, 08:36 AM
Last Post: toseland
  Lucas to Bosch Conversion Phase 2 306 DTurbo FrostyHDI 2 3,365 01-12-2015, 02:43 PM
Last Post: Dave
  Lucas to Bosch help simonson1982 22 10,869 28-08-2015, 05:16 PM
Last Post: blinkyeatu
